Twin 76 first drive video.
Old Oct 20, 2008 | 01:10 PM
  #61
camarols1's Avatar
Looks great!!!!
The plugs are obviously pig rich, so go get the beast tuned and you will be all set.
The car is loading up the plugs so bad that it will not idle.
The existing tune is probably way off.
Where did the base tune come from, does it match your injectors at least?
+1 on not driving the car until the tune is sorted out.
Old Oct 20, 2008 | 01:15 PM
  #62
sevanseriesta's Avatar
Originally Posted by Josh @ KYTP
The twin 76mm Setup was built in house by myself at Kentucky Turbo & Performance Inc.
The clean up on the car does look awesome. I have alot of work to do on my 02 Z28 to get the shine back.
The guy who did my clean up is phenomenal. His car is pristine, and takes a lot of pride into what he does.
Old Oct 20, 2008 | 01:16 PM
  #63
Originally Posted by camarols1
Looks great!!!!
Base tune is from speed inc... So are you guys saying that it is not missing. It is tuned for my injectors.
Old Oct 20, 2008 | 01:23 PM
  #64
here is a video of it at idle if this helps at all!
http://www.youtube.com/watch?v=XLRPksd14D4
Old Oct 20, 2008 | 01:28 PM
  #65
MECHAM's Avatar
daym...very nice setup indeed!! is this a beta kit? i dont see a tt kit on ky's site
is that running through a dump? (exhaust)
but seriously all that and no hptuner/efi to monitor the ecu... :shakes head:
Old Oct 20, 2008 | 01:30 PM
  #66
sidewayz28's Avatar
what kinda products does he use? looks excellent
Old Oct 20, 2008 | 01:49 PM
  #67
I believe just a one off kinda thing if I remember correctly. That was built a couple years ago and has been passed around if I remember the story correctly. Yes Is just running trough a open down pipe right now. It will be getting a short 4" pipe and a 4" bullet and then a turn down nothing special.
And I am working on a EFI now. Sorry was expecting the base tune to be a little closer!
Old Oct 20, 2008 | 01:51 PM
  #68
Its all mothers... I am not sure if you have ever seen Fad2blk's car if not do a google search, and i think that it is the first car that comes up. I do all of his performace work, he does all of the cleaning
Old Oct 20, 2008 | 02:43 PM
  #69
camarols1's Avatar
Speed Inc. sure as hell knows how to tune, so I would think their base tune would be close, especially just driving the car around at light throttle.
Did they do a 3bar speed density tune? Do you have the correct MAP sensor installed?
It could be possible that there is a large vacuum leak or that something else is wrong causing an overly rich condition. Is the fuel pressure ok???
Step one would be to take the car to a shop to check the tune, or invest in HPT or EFI Live so that you can see what is going on.
Without tuning software it is going to be difficult to get a handle on this in a timely manner.
Old Oct 20, 2008 | 03:04 PM
  #70
I am trying, to purchase EFI Live now.... so we will see what happens. I will see if they did 2 bar or 3 bar... I have a 2 bar sensor. I will see what I can find out
Old Oct 20, 2008 | 03:50 PM
  #71
Josh@KY-Turbo's Avatar
The kit was a one off I did for a customer in CA.
I have doen a couple twin setups since then. Made some changes, but overall the setups remain the same style. They are built as a one off. I just did the hot side. Sevanseriesta took car of the cold side.
Old Oct 20, 2008 | 04:28 PM
  #72
Fad2blk_98's Avatar
Thanks for the comments on the cleanup.
Mothers Claybar
PC and an intensive polish from Tropicare
Mothers wax and sealant.
Old Oct 20, 2008 | 04:36 PM
  #73
sidewayz28's Avatar
Mothers Claybar
Thanks man! guna have to invest in some of this stuff. My babies been dirty way too long.
Old Oct 20, 2008 | 06:26 PM
  #74
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Do any of the guys think spraying something like wd40 around the intake when the car is one is good for finding vacuum leaks?
If you had a scanner or HPT, you could look at the idle fuel trims. -25 for example one side is a sign that there is a big vacuum leak on one side or something is screwed up for that sign to run maxed out lean.
I'd check the fuel trims first before doing too much work. If they are equal, then look at what is going on with the fuel trims. You can tell if the car is too rich at idle.
If you started/stopped the car a lot befoe driving it you can foul out the plugs.
And those plugs do look pretty black.
MAF Translator is another little trick, you can use it to lean out the fuel at part throttle and see if that helps but I think your tune might be too rich.
Old Oct 20, 2008 | 06:55 PM
  #75
How do you use the wd40 to check for leaks is this the same as using the gas from a tourch. The car should rev. I am curious never heard of this before!
Old Oct 20, 2008 | 07:01 PM
  #76
blacksi's Avatar
The paint looks awsome and so does the setup. Twins on a 347 seems like a little excessive but if it's built to handle it you will have a blast.
It really sounds like you forgot to put the new cam in and left the MS4 or Trex.
Old Oct 20, 2008 | 07:19 PM
  #77
I am trying to work that bug out give me a little bit I will find out what it is
Old Oct 20, 2008 | 07:22 PM
  #78
98Camarod's Avatar
Yes, thats what I was saying to do earlier
Old Oct 20, 2008 | 07:32 PM
  #79
Reject's Avatar
got a angle shot of the one on the passenger side? i wanted to do mine like that but couldnt think of a way to do it
Old Oct 20, 2008 | 09:23 PM
  #80
LS1Tech Co-Founder
Same idea as using gas from a torch. If you have a vacuum leak that gas will get sucked in and your engine will rev up for a second.
