LS2 Aluminum Block question??
Old 10-26-2008, 06:19 PM
  #41
02SSLE's Avatar
I know you want to go faster Hunter. I think Wormboy is running an LSX block. Proven setup. They are running mid 7's. If I am not mistaken the NMCA rules makes you weigh arond 3400 pounds. If you go with a Warhawk block you can't run in the LSX shootout either.
Old 10-26-2008, 06:38 PM
  #42
HUNTER02SS's Avatar
I am not worried about being to light since I am not racing in any class's.
The LSX seem's to be the simple choice.
Old 10-27-2008, 10:33 AM
  #43
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
You'd be hardpressed to find anyone running low 8's or faster who is running a 4bolt setup and who's not pushing water on every pass.
I'd go 6 bolt LSX or ERL, and then you won't have that problem.
Old 10-27-2008, 11:00 AM
  #44
8 second mod
Noyzee's Avatar
my heads cracked for difrent reasons, we wont get into that tho, people weld heads all the time.
as for the block, i went good power with my ls2, but im super happy with the lsx, super super happy.
Old 10-27-2008, 11:07 AM
  #45
HUNTER02SS's Avatar
My block will not be a 4 bolt after it is finshed. I just can't see taking the extra weight out of my car just to add it back with the big iron block. If I did that I would just go with a BB chevy.
Old 10-27-2008, 11:10 AM
  #46
Frank02L's Avatar
Whats the ERL setup cost?
Old 10-27-2008, 11:26 AM
  #47
HUNTER02SS's Avatar
Just the block is 4500.00!
Old 10-27-2008, 11:29 AM
  #48
Fireball's Avatar
ask around...you'll probably find out that a properly prepped LSX isn't much different
Old 10-27-2008, 12:17 PM
  #49
Frank02L's Avatar
Weren't they setup at the shootout? I thought I saw them, then went to watch some racing to come back and they were gone. (Sunday)
Old 10-27-2008, 12:25 PM
  #50
Fireball's Avatar
yes..they had a block on display...I wish they brought their cutaway model that showed stock LS2 on one side vs ERL LS2 on the other
Old 10-28-2008, 03:28 PM
  #51
Quick Carl's Avatar
We will have the cut-away of a stock LS2 vs. our 6 bolt SD1 at SEMA and PRI if you make it there. Sorry, It wasn't finished to make it to Memphis and that we left Sunday and missed you. We had a long drive back to be back in Monday. It was great getting to meet a lot of people in person and see some good racing.
Just to clear the pricing question and compare apples to apples, With a good core the basic aluminum SD1 6 bolt block with the trusses, heavy ductile sleeves, decked, bored, honed, align honed, machined for 1/2" head studs is around $3100. If you want everything including doweled billet main caps, main studs, clearanced for a stroker crank, hydraulic or solid bronze lifter bushings, then your around $4200.
Old 10-28-2008, 03:47 PM
  #52
HUNTER02SS's Avatar
I was quoted $4500.00 for the block machined and ready to go, but I did not have a core block so that was added as well. If I can find a good cheap core then this might be a better route??
Old 01-06-2009, 09:00 PM
  #53
Cobra Commander's Avatar
Originally Posted by KissMySSo1
ive seen some cylinder walls cracking on even the LSX block. making apprx. 1100rwhp(nitrous). tuneup what perfect. pistons were fine just two cracked walls. plus the LSX block weighs 10000000lbs. i plan on buying the warhawk block next
Wow, that's the first I've seen of that with the LSX.
Old 01-07-2009, 08:53 AM
  #54
HUNTER02SS's Avatar
I chose to go with the LSX Block. I am building a 427 with 6 bolt ETP heads.
The shortblock is assembled. Just waiting on ETP to get me my heads back! If i knew they were so slow, I would of got a different brand head!!
Quick Reply: LS2 Aluminum Block question??
