Forced Induction Cam
Old Oct 29, 2008 | 05:12 AM
EPP's Avatar
EPP
Question
Originally Posted by cbr600rx7
My mechanic thinks the EPP will be too hefty for the 60 trim?
I don't see the logic behind why it would be a problem. Bob
Old Oct 29, 2008 | 05:13 AM
EPP's Avatar
EPP
Thumbs up
Originally Posted by jmdgto
i have the epp cam. still 25mpg on highway, was a dd . it is good on the street.
That is good to see, and the GTO's are a little heavier to boot! Bob
Old Oct 29, 2008 | 11:34 AM
cbr600rx7's Avatar
So you dont see the cam as being a little too "hefty" for the 60 trim.
Old Oct 29, 2008 | 11:52 AM
bad2dbone's Avatar
i heard the torquer 1/2/&3 are really good from tx-speed for blowers
Old Oct 30, 2008 | 12:16 PM
cbr600rx7's Avatar
For you guys running the EPP or a other cam of like spec. How does the cam fill in the low to mid of the power band and how does it hold up on top. I understand this is not a huge cam just looking and should produce fair power across most of the power band just looking for a little more feed back from owners. You could say i am still debating to go with my tech that thinks its too big or run with the EPP vs his advice.
Old Oct 30, 2008 | 12:55 PM
cbr600rx7's Avatar
Also for you guys running the EPP with springs what kind of RPM range are you running in.
Old Oct 30, 2008 | 09:02 PM
EPP's Avatar
EPP
Thumbs up
LS2-402 with AFR heads/EPP camshaft, LS2 intake, LS2 throttle body, Kooks 1-7/8 headers, ATI ProCharger F-1A at 14.4 psi of boost in a Caddy CTS-V
Bob
Old Oct 30, 2008 | 10:15 PM
383lt1impala's Avatar
i have a turbo cam for sale. i pm'ed patrick g and he said it looks like a real good turbo cam.
Old Oct 31, 2008 | 03:27 PM
cbr600rx7's Avatar
What about a slightly milder cam around 228/234 .609/.609 LSA115
Old Oct 31, 2008 | 03:48 PM
99 black ss sj's Avatar
custom ls1 turbo grind camshaft 234/234 .576/.576 112+1
Old Nov 1, 2008 | 11:10 AM
STAR's Avatar
__________________
black 99 ss
408 boost build by speed In,
AFR 225 Heads
BM shifter
borla exhaust
long tube ceramic headers
textralia oz700
Just curious how much power are you putting down with that set up?
Is that textralia single disk clutch capable of holding your power?
Thanks
Old Nov 1, 2008 | 11:57 AM
  #32
67Firebird455's Avatar
Wow man, a 27x cam? EESH dude, that is BRUTAL. What kind of drivability do you get out of that? Trailer queen? Thought I was doing decent on the 408 with an MTI R1 cam. Wanted decent street manners, and it's also going to be twin turbo, so wanted quick spool on the street but the ability to pump some air into it!
Old Nov 2, 2008 | 12:27 AM
  #33
Thanks
the car is not tune yet, i am on the braking in period i need another 100 miles on the motor before i get it tune, so far the clutch is holding just fine, i am not expecting that much of power since it is low compression motor 9.1
Old Nov 2, 2008 | 04:03 PM
  #34
less10's Avatar
compression doesnt have anything to do with the overall power of the motor.
Old Nov 2, 2008 | 06:06 PM
  #35
calongo_SS's Avatar
you sure about that dude? Compression is a major part of making power.
Old Nov 2, 2008 | 06:50 PM
  #36
do some research before you make comments like that lol
Old Nov 2, 2008 | 07:46 PM
  #37
Monte4ever's Avatar
WOW!!!
Old Nov 2, 2008 | 09:36 PM
  #38
DanWS6's Avatar
Old Nov 2, 2008 | 11:13 PM
  #39
less10's Avatar
On a turbo motor your going to tell me compression has to do with overall power?
Please please enlighten me. When you use a turbo and max it out, doesnt matter what compression you have the end total will be the same.
Now if your talking about just running a measily 8psi through a turbo that is capable of 1200whp. Then yes compression will make a difference in power.
And compression only adjusts the position of the power curve in reference to the rpms.
Old Nov 3, 2008 | 02:46 AM
  #40
cbr600rx7's Avatar
Compression is a huge factor in all engines including forced induction and nitrous applications. And it is a direct factor on overall power even on a turbo or SC engine. Lets say you are building a street car with a mild turbo set up. You want to run mild boost but still maintain pre boost power. You may drop your compression down to 9.5-1 or 9.0 -1 so you can run that higher boost. But how do you get boost in the first place. Is it not in direct relation ship to the exhaust gas pressure and the engine breathing out that has a direct relationship to the engines compression if i am not mistaken. And is a huge factor in how much boost you can run and where. And 8 PSI could be a lot of boost depending on the size of the turbo.
Keep in mind this is in your own words: compression doesnt have anything to do with the overall power of the motor.
