Forced Induction Cam
I wanted a lopeless cam and I got one. No surging no problems ,well stalling very occasionally but thats my lack of tuning at idle. Will figure it out. Also by staying lower on the lift you won't need to change out valve springs near as often.
why do you want to put a bigger cam in?
stock motor will only sustain so much hp big cam or stock cam
UNLESS the mod is ONLY to give you some certain sound you are looking for SAVE your money toward a built engine.
Might find this interesting..so buy stock one if they are cheaper. Ling are custom and might have different ramp rates and stuff..not all specs are on paper.
ng and z06 cam specs.
01 ZO6 cam: 204/211 .525/.525 -116 LSA
Lingenfelter GT2 205/212 .540/.540 –116.5CL
02-03 ZO6 cam: 204/218 .551/.547 -117.5 LSA
Lingenfelter GT2-3 207/220 .571/.578 –118.5CL
05-07 ZO6 cam 210/230 .561/.557 –120.5 LSA
Lingenfelter GT7 208/230 .554/.546 –121CL
Pretty simular don't you think?
The last two were their main fI grinds in almost all their builds. The gt7 is their current main fi grind. All the above will work fine in stock engines and in bigger ones.
MM
