Patriot Duals the best spring for FI?
Old Oct 30, 2008 | 08:45 AM
Monello's Avatar
Default Patriot Duals the best spring for FI?
Motor is stock as of right now. I want to put some 317 heads in it, and figured I would upgrade the springs as well.
What do you guys think?
I know EPP sells the Patriot Duals with the lockers for like 255.00.
Old Oct 30, 2008 | 09:18 AM
veee8's Avatar
They make the Patriot Extreme's that work well for forced induction and N2O.
Old Oct 30, 2008 | 09:35 AM
SSilverSSurfer's Avatar
i hope they work with FI because thats what im running : (
Old Oct 30, 2008 | 10:14 AM
Schantin's Avatar
Iv'e run Patrioit duals for the past 3 years, both FI and high-revving NA. No issues to date
Old Oct 30, 2008 | 10:18 AM
FANTAZ28's Avatar
Moderator
speed inc has them in stock.
http://www.speedinc.com/cont.cfm?cid=C0000152
free shipping to
Old Oct 30, 2008 | 04:50 PM
Monello's Avatar
I will keep that in mind.
What pushrods do you guys recommend? Its a stock cam at the moment. Would like pushrods that are compatible with an LS6 cam in case I go that route in the near future.
Old Oct 30, 2008 | 05:27 PM
Schantin's Avatar
I ran Thunder Racing 7.400 length hardened rods for 15K miles w/ no issues. Revved the car to 6800 on at least 100 1/4 mile drag passes. New setup has Comp Cams 7.450 hardened rods. Run them to 6700RPM at the track. Have 2K miles on those. No issues yet.
Old Oct 30, 2008 | 05:40 PM
Reject's Avatar
wish Speed would sell the springs alone if we already have the otehr stuff you know.
i run them BTW on my car, from my N2O to my MS4 now the TC76
Old Oct 30, 2008 | 05:58 PM
OUTLAWZ RACING's Avatar
When I bought the patriot 317 heads 3 years ago the came with the dual springs. The heads where un touch and bolted on and 7k rpm shifts and more boost no valve float and I have a big cam in it too.
Old Oct 30, 2008 | 06:08 PM
cam's Avatar
cam
I've searched and searched and never I mean NEVER found one post with a Patriot Gold failure. I think they are the best springs period
Old Oct 30, 2008 | 08:55 PM
EPP's Avatar
EPP
We use Patriot Gold Springs in virtually all our builds. We have never had a problem with them, and we run a lot of boost with them. This car that sees a lot of road course work is a prime example. http://www.exoticperformanceplus.com...Car.php?car=40 Bob
Old Oct 30, 2008 | 09:06 PM
Z06PSI's Avatar
Patriot Golds here with Thunder hardened 7.400 push rods.
Old Oct 30, 2008 | 09:20 PM
Jimmy P's Avatar
Make sure you give them adequate seat pressure. My ETP's came with Patriot Dual valve springs, and I was getting a ton of valve float. We had to take the springs off and shim them. Its time consuming to do, so make sure you shim them properly the first time.
Old Oct 30, 2008 | 10:55 PM
Monello's Avatar
Thing that these will be the way to go.
Just need to pick a hardened push rod. May go with the thunder's.
Old Oct 31, 2008 | 01:37 AM
ninetres's Avatar
Regular or Xtreme?
Old Oct 31, 2008 | 03:38 AM
Lawnboy's Avatar
Restricted User
Are the Texas speed and Crane dule-double springs the same as the Patriot Gold Springs???
I have the Texas speed spring kit , they are going in my new Forged LS6 blower motor. How are these? any special thing needed the be done to them to work, shimming etc.
Old Oct 31, 2008 | 05:22 AM
tomz28's Avatar
i run patriots on my 317 and a ls6 cam
Old Oct 31, 2008 | 09:39 AM
Monello's Avatar
tomz28 do you run stock pushrods and rockers?
I am also going to be running a 317 and ls6 cam
Old Oct 31, 2008 | 06:02 PM
cam's Avatar
cam
Theres not much difference between aftermarket performance brand push rods fyi. I'd buy whatever you can get the best deal on. I'm running comp 7.35's now ( milled heads so needed shorter ) and I have run Manley as well in this engine. Both handled 7K rpm no problem
Old Oct 31, 2008 | 09:23 PM
52172's Avatar
can't go wrong with the patriot springs they are the best for the money. If you know you are gonna run boost you should go with their extreme spring no doubt about it. I went with comp 921's, but when it comes for a spring change I plan on saving money and going with the patriot extreme.
