Patriot Duals the best spring for FI?
#42
I used the PRC duals on my old set-up and have no complaints. I had a cam with .598 lift and pushed 14psi on them with a nice smooth graph all the way to 7000rpm and 680rwhp on a stock block with 317 heads. Now my new cam is bigger and I'm going to be pushing more boost so I needed a spring that could handle more lift but also have a higher seat pressure, that's the only reason I went with these new ones I posted.
#43
I dont know about the PRC specs but the rev limiter is at 7500 (saw upper 6k's with the new motor 1st time out) now and we made 24psi on them and didnt have any signs of weak springs.
