Looking to go turbo LQ9
I'm doing an LQ9/t56 swap in to a 95 RX7
couple of questions, I tried searching but most things only cover LSx engines
can I use a stock long block safely? will have ls style intake manifold (ls1 or ls6) upgraded injectors and rails, plan on doing the truck manifold turbo manifolds to a Greddy T78 and a Greddy FMIC
do I have to upgrade the valve train right away?
from what I am reading is seems the bottom end of these (LQ9s) are pretty FI friendly so I hope to use that for a while while I can
I'm looking to make ~500whp which I'm sure this should be no problem with a turbo this size and the proper fuel set up.
this turbo was used previously on the 13b rotary and made over 500 to the wheels
also open to any reccomendations as to how to make this work
LQ9's will hold 500rwhp like nothing. my stock internal'd LS1 can (made 512rwhp @ 7.5psi)
that turbo might not be sufficient enough for the LQ9 (i.e. the LQ9 puts out way more exhaust than the 13b im sure)
60lbs are a must and i would go a little further than a 255lph for fuel pump
all of this is JMO
its a 66mm turbo with an external wastegate, those rotaries will surprise you with the ability to spool big turbos
i've never been a fan of them i am just helping a freind get away from them and over to LSx power, his deal was, that it has to use this turbo, and have over 500whp which i told him would not be a problem AT ALL, i know its capable of well over that, but we would like to keep this thing a streetable weekend fun car
I my self am doing an LS2 s13.5 240sx, and using a walbro 255 in tank, for the stock engine, this will be enough fuel for a turbo v8 as well?
I'm just trying to figure out exactly what valve train upgrades will need to be done to do this, minus the cam, he cant afford that right now..
