i broke it...looking for imput/suggestions
The noise you you're hearing could be a broken chip banging off of the cylinder head or a broken ring that is rattling.
The correct fix is to use forged pistons that are gapped correctly for use with turbos. Time to forged the lower end or you'll be back here again.
Spend a couple of bucks and get some rods too, then you'll be set.
Some guys get lucky and others not so lucky. If you're willing to live with less boost for awhile then go stock.
