LS3/L92 head gasket?
Old Nov 4, 2008 | 10:55 AM
Yellowsierra's Avatar
Default LS3/L92 head gasket?
I heard the LS3/L92 is a really good MLS head gasket. It has 5 layers of steel instead of 3 like the 6.0L head gasket. Will this head gasket work on my LS1? Its a 3.905 bore. I have the 6.0L head gaskets but Im trying to lower my compression alittle more by using the L92 head gaskets. Thanks...
Justin
Old Nov 4, 2008 | 11:04 AM
Justin
Well it must work because cometics are 4.165 bore and they recommend them for LS1 and LS2 engines. The LS3 head gasket is a 4.100 bore.
Old Nov 4, 2008 | 11:57 AM
ss1's Avatar
ss1
It's the 6.2L 5-layer MLS gasket that quite a few people have used, and it has a 4.100" bore.
I'm not sure about your application, but there are some other posts around here discussing where that gasket has been used with success.
Old Nov 4, 2008 | 12:19 PM
67Firebird455's Avatar
Are you guys talking about GM #12610046? I just ordered a set, .051" thick, 4.080" max bore. 5-layer MLS like the previous 6.0 (3-layer), and great for boost, which is why I got a set.
Old Nov 4, 2008 | 12:26 PM
Ive got a set of the 6.0L MLS head gaskets. They have been bolted down one time with about 50 miles on them. Im thinking about spaying alittle copper seal on them and reusing them. Do you think this is a bad idea?
Thanks
Justin
Old Nov 4, 2008 | 12:32 PM
For the money? Those 6.0 MLS gaskets are cheap dude, and usually in stock at the dealer. They're less than $50 for a set. I mean, I'm sure you could get away with it, but on a FI setup, is it worth the pain in the *** later?
Old Nov 4, 2008 | 12:49 PM
camarols1's Avatar
Why take a chance used gaskets? Especially on a boosted engine.
Old Nov 4, 2008 | 03:46 PM
Gauge's Avatar
11Second Club
So, the 5-layer LS3 gasket is .051" thick while the 3-layer LS1 gasket is .054" thick? Is that right? Sounds off.
Old Nov 4, 2008 | 04:13 PM
Yeah I would like to know this as well. I heard the 6.2L MLS gaskets where 4.100" and .055" thick. I will probley go with a set of these if thats right.
Justin
Old Nov 4, 2008 | 04:54 PM
Byunspeed has it listed as .051 thick, and a 4.080" max bore.
http://www.byunspeed.com/product_inf...d738cbd5ed0493
