Custom Rear mount turbo
The built motor in my truck makes around 80 psi oil pressure at full tilt and I have no oiling issues at all.
http://i29.photobucket.com/albums/c2...00TASTS004.jpg
http://i29.photobucket.com/albums/c2...00TASTS003.jpg
http://i29.photobucket.com/albums/c2...00TASTS007.jpg
http://i29.photobucket.com/albums/c2...00TASTS008.jpg
http://i29.photobucket.com/albums/c2...00TASTS010.jpg
http://i29.photobucket.com/albums/c2...00TASTS006.jpg
http://i29.photobucket.com/albums/c2...00TASTS012.jpg
I work for STS, and I have seen time and time again 75 % of everyone who has tried to make there own rear mount turbo system, has spent 1000.00 more then our base system will cost. Now I am not telling you to purchase our system, just make sure you do your home work. I can give you some tips that will help.
Use stock manifolds
Wrap your Y pipe all the way to the turbine housing
Run a turbine jacket
Stay with 2-1/2 exhaust pipe
Use at least T4 frame turbocharger
Stay small on the turbine housing
Return oil in valve cover or oil fill cap
As far as the oil pump, I can tell you that there are alot of after market oil pumps out there that claim they can stand up to the punishment of the remote turbo system, I have yet to find any of these pumps and there claims to work as good as our pump. It took us years to find a pump that would hold up against the high demands and stresses remote turbo dishes out. The oil pump is the key to making this system a fun and enjoyable, for the daily driver. Now alot of people do not know this but here at STS I have a system that will sell you the propper turbo, our oil pump, and waste gate. This is out stage 1 universal system, it takes all the guess work out of finding the correct size turbocharger for you car, and gives you he same oil pump ran in all of our systems, and still allows you to build your own kit. I am not on here to sell our systems I am telling you all of this, so remote turbocharging wont be blamed incase the system you make does not work.
Good luck, and if you have any questions let me know, there is alot that I cant tell you but what I can tell you is remote turbocharging is a great way to make alot of safe power, if done correctly.
Explain to me what you call the damn things, oil retainers, or what the keep the oil from coming out of the cartridge and either leaking into the turbine or compressor sides of the housing.
I basically built it with a lot of the new STS ideas but that kit wasn't yet avaible it was several months out. As for better, there are a few minor problems with the STS kit IMHO. The charge pipe from the turbo and the oil drain to the pump are both routed over the axle. Like I said before I ran everything under the axle. Since the pipe doesnt turn left and go under the LCA it actually has better groudn clearence there and is less likely to scrape since it is directly in line with the rear wheels and not immediately in front of them. So going under the axle removes a couple 90 degree bends and about 2 1/2 feet of piping. Also with the Oil Drain running over the axle any oil left on the turbo side of the lube naturally puddles back in the turbo and leaks oil out the seals, under the axle the line is the low spot and the oil pump has an easier time getting the oil away. Also with an Intercooler the have the Wastegate boost reference straight off the turbo housing it tends to make for unstable mainfold pressures. What I mean by that is the Turbo will spool, create boost enough to openthe wastegate, but then it has a hard time filling the intercooler and all the piping so it drops about 2 psi or so between 4000 and 5200 rpm. I ran a hardline form the intake back to the wastegate and adjusted the spring to provide the correct manifold boost pressure throughout the entire rpm range, it seems to work much better. I'm not saying the kit I built is superior I just think it makes a little more sense.
I think people have had good luck with the Mocal pump.
