what kind of power u guys making
Example you can run my little stock 97 talon turbo at 20psi and it won't make anywhere near the power that my big garett will make at 20psi. The reason is airflow.
The smaller turbo might be rated to flow max 25 pounds /min and the big one 65 pounds minute which works out to 650 engine hp on the big one and 250 max engine hp on the small one.
So put a big enough turbo on that car of yours with a 408 even with stock heads and can't see any reason you can't hit 850rwp at 15psi. No idea if the turbo you are looking at can do it. I am hoping to hit 850rwhp on m6 with possibly the standard aps twin turbos but do have good afr heads. Heads are going to make more power with less boost than standard heads or milder cam. Even better intake can help you make more power at lower boost. The rules of NA are not totall broken for FI. a stronger engine off the start is still going to be a stronger engine fi it will take less boost to make same power as the weaker one and it will hit a higher max power potentially as well.
I'm thinkin like a 9 to 1 compression...yea 650 to700 is bout the max I wanna make on the street but I wanna be able to turn it up some and get a little More out of it at the track u know like a race gas tune but I want it to be safe and if I will be pushing the reliability of the stock heads get over 800 then ill look into some afr or trick flow... I have the rear suspension to go nines that is not a problem...
And if you have the money then go for some better heads. Then you won't be as limited and will make more power on and off boost and more power at less boost.
