Need LS1 Edit files, wanna look at tuning for boosted cars
Hello guys, I'm looking for a few LS1 Edit files that are from 98-02 F-bodys with a ATI Procharger on it.
I'm helping out a few people with boosted cars and I want to see what you've done with your tuning so I can have something to go off of. I will be tuning on a dyno.
I know I can't copy tables, but what to see how close my tuning is to yours, to get similiar results (HP, TQ, & Air/Fuel)
If you don't have your files but know what tuning has been done that works, please if you could list them in this thread or email me. Also, send me part throttle tuning tips if you have them and want to share them too.
Thanks in advance...
Please email them to - wwright3@insight.rr.com
Bill
Bill
Re: Need LS1 Edit files, wanna look at tuning for boosted cars
wonder if you can look at mine, you can if your able, but im not sure how you can see them if its possible (of coarse you know i got a turbo)
i got efi live, can you use that to record the data?
have you asked Tom, hes got an ATI.
My PE didn't change much from stock, but the timing from .80 to 1.2 g/cyl dropped to a low of 12 at peak torque and rose back up to about 15. With an intercooled setup, you can probabaly get close to twenty. It is going to be tough to just copy somebody elses file, though. I tried copying somebody's injector table who was running the same injectors as me, and even that didn't work. Every car is different.
For part throttle, I first locked in the full throttle A/F (tuned at Detroit Speedworks) then re-sloped the injector table to line up the part throttle LTFT's (change the starting point of the table, but hold the end constant. I know it sounds backwards, but I ended up with 450 out of a powerdyne, so something must have been right. Just don't change that last cell on the injector table once your dialed on a wideband.
-Geoff
-Geoff
I don't want to copy anyones table, just want to look at it.
I know every car is different, but just want to look and compared to a N/A file.
i emailed mine to you
single turbo, low compression stock displacement pump gas 15psi.
*the helpful serious racer *
Sorry to be a pain Mighty Mouse but can I see that file too? I've been helping a lot of people with the LS1 edit stuff locally but I've never seen a well tuned turbo file.
thanks
