Procharger tensioner bearing seizing!
I have a 98 Camaro running a F-1 Procharger. After the install at about 3k miles the belt tensioner seized. OK so I ordered a replacement from Procharger installed it and thought everything was OK. 5500 miles later... same thing, the tensioner seized again. I've had all the work done at a very good shop who installs allot of blowers. He prefers Vortech and says it’s a procharger quality issue. Any ideas what could cause this? Has anybody else seen any problems with Prochargers belt tensioners? I really like the F1 Procharger but I need this thing to be reliable because it's a daily driver.
Thanks
Thanks
We don't typically see problems like this very often. In your case since the car is driven daily you are probably going to run into this much sooner than most people do with an F1 blower on an F Body. The ProCharger GTO and Corvette bracket design is superior to the F Body system, and the SDCE tensioner assembly would probably take care of your problem, as the belt would not have to be kept nearly as tight. Bob
so im taking it for those people who DD there procharged (or maybe specifically F1) setups they should invest in the SDCE? im just asking cause im planning a build that will be a DD so better to do it once and do it right.
