Plug Reading
Old Nov 23, 2008 | 02:11 PM
rx_treme's Avatar
Default Plug Reading
What would this plug indicate to you guys?
The plugs were brand new gapped .29 TR6's with approx 70 miles on them. Its a Whiteish coating (very thin) with a blackened base ring. The whiteish coating scrapes off with a finger nail.
The car runs great in vacuum up until 0 vac or boost then stumbles badly.
The tuner (nicD) said everything looks great on the tune and AFR's are good. No codes.
I'll give more details after I finish the compression and leakdown test in a few.
Old Nov 24, 2008 | 02:21 AM
rx_treme's Avatar
Just got finished with the compression test and leak down.
1-185 2-180
3-185 4-170
5-170 6-180
7-195 8-170
All cylinders less than 5% leak down. although i can still smell the oil smell being pushed up through the breathers on the leakdown test. I can also kinda hear it coming from breathers.
Any ideas?
Anyone else have this problem when going into boost?
I only have two things left to try. A new Map sensor and a fuel pressure gauge to read while driving.
Old Nov 24, 2008 | 07:42 AM
OUTLAWZ RACING's Avatar
Are u running a maf? If so take a look at it and make sure its clean. Seems like the car loads up on fuel when boost comes in recheck the tune.
Old Nov 24, 2008 | 10:34 AM
rx_treme's Avatar
No, no maf, but thats exactly what it feels like.
I'm gunna swap the map sensor and throw a fp gauge on it just to see if it changes.
Old Nov 24, 2008 | 11:06 AM
ls1290's Avatar
Dumb Ass Vette Moderator
The white coating is a good indication you are running lean, way lean. Recheck your tune looking at the PE multiplier.
Old Nov 24, 2008 | 02:31 PM
sevanseriesta's Avatar
I also agree on way lean, I can not even idle my car for 10 mins right now with out failing to plugs. Put Mine are pitch black... Do you have a A/F gauge? What does it say!
Old Nov 24, 2008 | 02:34 PM
rx_treme's Avatar
yea Wideband says around 15 at cruise and dips to 12-13 when it starts stumbling at about 0 manifold pressure.
Thanks for the help guys, keep it coming!
Old Nov 24, 2008 | 04:50 PM
crashly's Avatar
you cannot read a gas plug by just looking at it...
methanol yes, gas no
the thread has to be cut off, and the fuel ring looked at , right down the bottom of the white porcilin.
or
an eye piece , magnifing glass used to look down inside the threaded section
the only thing read on gas plug is the timing mark on the electrode.
ash
Old Nov 24, 2008 | 07:41 PM
hellbents10's Avatar
LS1Tech Sponsor
Agreed, that and signs of detonation as noted by black spots on the porcelain.
Old Nov 24, 2008 | 11:27 PM
crashly's Avatar
...and the dreaded tiny ***** of alloy....
Old Dec 5, 2008 | 03:51 AM
rx_treme's Avatar
So I figured it out.
7 of 8 spark plug wires were burnt/charred/arcing and falling apart.
New spark plug wires and fire boots fixed it.
Old Dec 5, 2008 | 04:39 AM
cablebandit's Avatar
fire boots cooked the wires on my incon and ofi kit
Old Dec 5, 2008 | 08:08 PM
rx_treme's Avatar
What do you mean, that the fire boots are what actually ruined your plug wires?
