OfI 4" Exhaust clearance pictures
Finally got all the tires and wheel so I could put the car on the ground so I could check the clearance for my exhaust. Right now the way it sits we have about 3.5" of clearance, but I have the car sitting really low right now. And also a couple pictures of the car. Making progress but im still collecting parts for the build.
![](http://i103.photobucket.com/albums/m147/zo6this/Donscamaro009.jpg)
![](http://i103.photobucket.com/albums/m147/zo6this/Donscamaro003.jpg)
![](http://i103.photobucket.com/albums/m147/zo6this/Donscamaro004.jpg)
![](http://i103.photobucket.com/albums/m147/zo6this/Donscamaro005.jpg)
![](http://i103.photobucket.com/albums/m147/zo6this/Donscamaro006.jpg)
![](http://i103.photobucket.com/albums/m147/zo6this/Donscamaro008.jpg)
man, having a oilpan that low would freak me out on a street car! Even coming down from a hard wheels up launch.
Kit looks sexy as hell! Car is deadly looking with that tire/wheel setup too
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
looks good man, my ofi is the same way with the 4" downpipe, being the trans being the lowest point.my car stock height though.Should make some nice power .I would expext anywhere between 850-1000 rwhp depending on how hard u push that s85.Good luck with the rest of the build
are u planning on running power steering or manual rack?if running power steering this will become hot as well from the headers.also what are u doing for spark plug wires.i would suggest u spend some time looking at the spark plug wires as those headers make the wires hot and can melt one like mine did.Lots of fire sleeve on there now.just a few of the issues we ran into on my build
Thank you for all the compliments guys. This has been a long build so far, things are getting a bit more expensive than I anticipated. Yes, the car is lowered. I am not sure how much in the front, but I have adjustable Strange Struts and I have adjusted the front end dwon quite a bit. I have Afco Rear Shocks and I have lowered the rear 3 inches from stock ride height. I will probably not run it this low, I was just looking to see what the clearance would be with the exhaust.
I am not sure if I am going to run power steering or not. Mad Man Racing has a manual rack that will bolt into a power steering K-Member, so I might go that route.
The wheels are Billet Specialty~ the front are 15x4 and the rear are 15x10.
Very clean, I like the stance as well, about the same as mine. I also have those same rims, looks great. Just a thought, if you put the manual rack in there, chances are it will interfere with that 4" DP like mine.
LS1Tech Premium Sponsor
Car looks bad ***!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
