How far has your inline pump taken you?
Old Dec 1, 2008 | 03:30 AM
Slow5.0.'s Avatar
Default How far has your inline pump taken you?
I am starting a new setup (turbo 6.0) I have 60lb injectors and a 255 hp intake pump and a gls340 inline w/ that. I am curious to see how far people have gone with this set up because I dont want to be pushing my luck and would like to do it right the first time. Hearing some numbers made on this set up will help me figure out whether or not I need to go w/ two inline pumps and a pick up. So far I have found only a couple w/ this set up that mentioned hp levels and those were at 585whp w/ no issues. Anyone make it over 600 issue free?
Old Dec 1, 2008 | 07:06 AM
sultan(ZR-1)KSA's Avatar
662WHP 044 bosch inline and 044 internal and only 60% duty cycle -10 line feed -6 return
Old Dec 1, 2008 | 01:54 PM
Slow5.0.'s Avatar
How do those pumps compare to the ones I am using? I have heard of the 044. I am pretty sure its a much stronger pump then a 255?
Old Dec 1, 2008 | 04:44 PM
thye are rated to 5BAR and flow as much as 300GPH
Old Dec 1, 2008 | 08:12 PM
Slow5.0.'s Avatar
i c... anyone else?
Old Dec 2, 2008 | 01:12 AM
Slow5.0.'s Avatar
Anyone?
Old Dec 2, 2008 | 01:35 AM
1320's Avatar
I ve got one in the mid 550's, one that made 653 I think, and one that made 588. The 588 actually has been turned up alittle and should be in the 660-690 area now, but it is at 100% DC, with the fp raised via adj fpr.
low 600's is about the limit, any more and you need to really watch it close.
Old Dec 3, 2008 | 02:15 AM
Slow5.0.'s Avatar
Yea, the pumps I would imagine would support less hp on an lsx because of the raised fuel pressure. The old set up I had was on a diff motor and was only at around 40psi. I am think I am going to play it safe and go with paralle 255's.
