383 and maggie potential #s
Old Dec 2, 2008 | 11:33 PM
themack56's Avatar
Exclamation 383 and maggie potential #s
how much power would a maggie and a 383 make. heads would be some 583 castings cncd, not sure about the cam, but it will be a blower cam, any #s u guys think it can make
Old Dec 3, 2008 | 12:03 PM
ls1290's Avatar
Dumb Ass Vette Moderator
I have seen a couple combos make about 600 rwhp, but those are pushing the limits of the maggie.
Old Dec 3, 2008 | 12:45 PM
98transguy's Avatar
580-600 would make tons of toque down low but lose it on the top end
Old Dec 3, 2008 | 02:27 PM
Sluggish's Avatar
Procharge it
Old Dec 3, 2008 | 02:29 PM
Ls1Rx-7's Avatar
ya the maggie would by out of breath way to early on a 383. a d1sc would be perfect for it and put down an easy 700rwhp.
Old Dec 3, 2008 | 02:57 PM
hellbents10's Avatar
LS1Tech Sponsor
Don't say that on performancetrucks.net (see radixtrucks.net) lol. I agree 550whp and they start being rated in BTU's.
They make for great 500hp drivers though, good for off idle smoke shows.
Old Dec 4, 2008 | 01:48 PM
BLNLS1/RX7's Avatar
How much boost?
Old Dec 4, 2008 | 08:18 PM
themack56's Avatar
Originally Posted by BLNLS1/RX7
How much boost?
7-8 psi, at what rpm would the maggie start to fall on its face?
Old Dec 4, 2008 | 08:29 PM
fish5225's Avatar
The question is which maggie? The new TVS 1900 does not fall off on the top end like the 112 or 122. My torque curve on a 408 was basically flat, averaging 650ft/lbs on only 5lbs of boost. This engine made 727 peak hp at 6400 rpms with no drop off except we ran out of fuel and had to shut it down. The new blower makes a big difference.
Old Dec 4, 2008 | 08:35 PM
themack56's Avatar
112.
i dont think i can put the 1900, i think the bolt pattern is different for the 1900
Old Dec 5, 2008 | 07:55 AM
Photochop's Avatar
Seems like 500/500 is a general trend with maggies.
Old Dec 5, 2008 | 05:25 PM
Z06PSI's Avatar
How about a 383 with a Kenne Bell? That would be nicer..
Old Dec 9, 2008 | 02:47 AM
Ls1Rx-7's Avatar
a kenne bell would be way better. if this is a street car i'd go with a Procharger or turbo setup, you will already have nice low end Tq from the stroker and it would be alot easier to hook up. And maggies are known to have heat soak problems and make your engine run hotter cause its bolted to the engine, so that could be an issue for you aswell.
Old Jan 12, 2009 | 01:04 PM
Steel Chicken's Avatar
with properly selected cam and heads, I get 655rwhp out of a 122, on an LS1
gobs of torque, at ALL RPM's
But, with the TVS's coming around, id go with one of them before a 112 or 122
with a 112 on a 383, expect somewhere between 550-600, depending on other factors
