Track results, CAS Twin Turbo
Old 09-25-2003, 12:54 AM
A DEE O's Avatar
Default Track results, CAS Twin Turbo
Four very consistent runs on BFG 315/35/17. Best pass was 11.6 at 128.9mph. Garbage 2.0 60ft. I was basically destroying the tires off my launch. My low trac was on all of 4th gear. I was ripping the tires the whole way down the track. Car felt great. This car is full weight and then some. Spare tire and coin holder, I left it as street trim. I have my shiftlight set for 5900 and it was going throught the traps at 6400. I will try Harlans 2 step again this time with the new heads. Maybe I can build more than 1 psi of boost? Overall, I had a blast
and am wowed by the almost 129mph trap. Angelo
Mike, please get me off the benched list, I haven't been down for quite some time. Thank You
Old 09-25-2003, 12:59 AM
Rob Raymer's Avatar
Default Re: Track results, CAS Twin Turbo
Congrats. Impressive mph. Now get some ET Streets and lay down a serious number.
Old 09-25-2003, 01:07 AM
A DEE O's Avatar
Thanks, Rob. I was set to run on ET Drags, but only seeing 1psi of boost with the 2step, bummed me out. I will hook it up again and if I can get 3-4psi, I will be on a slick before seasons end. Angelo
Old 09-25-2003, 06:01 AM
smokinHawk's Avatar
nice, congats, awsome 128.9 trap
were you running your 11psi on 100 octane then?
Old 09-25-2003, 06:02 AM
Turbo Addict
RICE ETR's Avatar
Nice mph... what rpm did you have the two-step set at? And how long did the car have to build boost before you launched?
also.. seeing such good numbers with that cam and a turbo makes me feel better about my TR for when i go boosted.... do you happen to have any before/after input with the stock cam/turbos and that cam/turbos?
Thanks
Old 09-25-2003, 07:12 AM
8 second mod
Noyzee's Avatar
GOOD MPH, TIRES my friend.
I got my 2-step in, but it was no good, Harlan is working on it now. That car has low low 10's all over it!!!!
Old 09-25-2003, 07:30 AM
CHRISPY's Avatar
Congrats!! Were you running race gas in the car? Nice numbers!! What rear end and gear?
Cheers,
Chris
Old 09-25-2003, 07:38 AM
7 Second Club
10.5 Dave's Avatar
Location: Grove City Ohio/Port Washington L.I sometimes
Put a good tire on that car,powershift it down the track and you should see 10.4-10.5s with your mph.129mph is impressive for a street car.
Old 09-25-2003, 07:46 AM
A DEE O's Avatar
Yes, thanks.
Old 09-25-2003, 07:50 AM
A DEE O's Avatar
Thanks
TR224 cam has been in the car before the TT kit. I had tried Harlans 2 step at 4500rpms and I only built 1psi of boost? That is why I decided to sell my et drags and remove the 2 step. Someone suggested it was because of the stock heads, at the time? Harlan, said it was because of the big turbos and stock cubes?
Old 09-25-2003, 07:56 AM
A DEE O's Avatar
Car has a Strange 12 bolt with 3'73 gears.
Old 09-25-2003, 09:21 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,160 Likes on 754 Posts
What heads and what is the LSA on that cam, 114 or 112?
Old 09-25-2003, 09:23 AM
CHRISPY's Avatar
I believe he is running stock heads but not sure.
Old 09-25-2003, 09:27 AM
Warbird's Avatar
Very nice run, your trap speed is higher than my car when it ran 10.9 , with a half decent hook you are easilly in the 10's
Keep up the good work
Paul
Old 09-25-2003, 11:51 AM
A DEE O's Avatar
6.0 heads, done by Jay at absolute speed, the cam is on a 112.
Old 09-25-2003, 12:08 PM
qqwqeqwrqwqtq's Avatar
Nice run! What was your 1/8 ?
Old 09-25-2003, 12:09 PM
A DEE O's Avatar
7.7, Jim.
Old 09-25-2003, 12:14 PM
Malicious's Avatar
Damn thats fast, TRACTION D:
Old 09-25-2003, 02:06 PM
Turbo Addict
RICE ETR's Avatar
00 Camaro SS M6-Onyx Black
Charged Air Twin Turbo
mods:all bolt on's, TR 224/112
Dynojet:522rwhp 518rwtq
Dynojet: (100oct)602rwhp 598rwtq 11psi
Old 09-25-2003, 02:07 PM
Turbo Addict
RICE ETR's Avatar
ahh yea... that would do it...
Quick Reply: Track results, CAS Twin Turbo
