My turbo oil drain solution
Old Dec 9, 2008 | 05:45 PM
dhdenney's Avatar
Rather not drill since I've put it together! I kinda almost like the oil pump return to the valve cover the best. (Thought I acknowledge some added costs.)
Old Dec 9, 2008 | 08:19 PM
dhdenney's Avatar
Talking to my dad tonight, he seems to think the pressure coming out of the turbo will overcome any back flow into the line. Keeping the return below the oil level will eliminate any foaming since there will be no air and he says you don't want it spraying on the crank anyway. Thoughts?
Old Dec 10, 2008 | 06:37 PM
MIGHTYMOUSE's Avatar
the return line doesnt 'spray back in' and there is no worry to how foamy it returns
try it, be prepared to move it if you get oil smoke out the exhaust
Old Dec 10, 2008 | 06:50 PM
dhdenney's Avatar
He seems to think pressure out to pressure in is 1:1. I kinda thought it just "drained" too.
Old Dec 10, 2008 | 07:08 PM
otherwhitemeat's Avatar
There is no real pressure in the return line.
Old Dec 10, 2008 | 07:20 PM
Black_98Z's Avatar
The drain line is larger than the feed line so no pressure problem.
Old Dec 10, 2008 | 07:58 PM
10sec_rx7's Avatar
7 Second Club
if you put it below the oil level your going to have a drain back problem and your going to get a lot of smoke and oil out the back of the turbo...
Old Dec 10, 2008 | 08:47 PM
dhdenney's Avatar
I think I'll just go with the scavenge pump.
Old Jun 1, 2020 | 08:47 PM
Turboradomike's Avatar
Default Turbo oil drain
I know it's an old thread. But eBay sales the oil level sensor adapter fitting to -10 and I'm using it as my oil drain with no problems. It works!
Old Jun 3, 2020 | 01:43 PM
Z32_5.3's Avatar
it all depends on your turbo drain flow... if your turbo drain had ALOT of oil coming out of it then it’ll fill that line up before it can let oil into the pan. So your turbo needs to put out less oil than the drain hole can allow the pan to fill up. It’s not pressured hose obviously so gravity has to push that oil in the drain line into pan that’s already fillled.
so if you took 2 cups and put a straw connecting them at the bottom of them. Start filling one and it’ll flow into the other empty one nicely. However once the 2 cups have same amount of water in them and it’s above the straw, the cup being filled with fill up faster than the 2nd cup. Anytime you stop filling, the 2 cups will always level out.
your turbo drain is the first cup being filled and pan is second that’s just filling off gravity. Your turbo drain line will ALWAYS have oil in it up until the oil height that’s inside the pan. So that already shortens up the available empty space in the drain line before oil backs up to turbo.
i would personally get a scavenger pump. I have the exo mini which has both my turbos going to it AND it’s mounted above the turbos alittle. Works great. I’ve seen s2000 turbo cars run drain off the pan drain bolt also. Just seems risky. I wouldn’t do it for twins if it’s working for single. Double the oil! For all you know, the oil drain is filled and inch or less away from turbo whole time it’s running.
By Brett Foote | 2026-06-04 05:00:17
