will this work?
Old Dec 10, 2008 | 10:02 AM
B18CYA's Avatar
Default will this work?
Wondering if this will cause any boost creep??
Old Dec 10, 2008 | 10:53 AM
1320's Avatar
not the way its pictured, you ll need a turbo and an engine to spin the turbo. LOL
I think the only way you will find out is to try it. Its a function of the engine producing so much exhuast that the turbo and waistgate combined can not flow enough exhuast for the desired boost level. Most of the time I ve encountered boost creep problems, it was waistgate set up and control issue however.
Old Dec 10, 2008 | 12:59 PM
black98ws6ta's Avatar
Should be ok. What you have pictured is not ideal, but would work for most. Engine size, turbo size, lowest boost level you want to maintain, and a few other factors will decide if it will not work properly.
Old Dec 10, 2008 | 01:11 PM
otherwhitemeat's Avatar
Why is that not ideal?
Old Dec 10, 2008 | 01:13 PM
67Firebird455's Avatar
It's supposed to be angled toward the incoming exhaust before it hit's the turbo. Being straight up like that with a "long" curvy pipe is not as good as "optimum" but with that large of a WG, it should still work okay for you!
Old Dec 10, 2008 | 01:36 PM
B18CYA's Avatar
thanks guys this is a 48mm progate and will be partnered with a S80/t6 and 402. Would also like it to hold 7 or 8 psi till funds permit stronger stuff out back
I agree.
Old Dec 10, 2008 | 01:48 PM
cablebandit's Avatar
ofi is kinda like that and a 44mm tial holds my s488 @ 7.5 psi with no probs....408 ci motah
Old Dec 10, 2008 | 01:50 PM
Tiago's Avatar
it will work.
Old Dec 10, 2008 | 09:01 PM
Sideways240sx's Avatar
I agree, should work. I have definatly seen way worse.
Chris
