GT47-88 L92 first dyno results!!!!!
Chris, glad to see everything came together! Congrats, I know the feeling of a build coming together after a year of saving, earning, and bleeding for the project. Results like this sure make it seem worthwhile!
Can't wait to see the big boost runs
OWN3D BY MY PROF!
Those resulst on 13ish lbs of boost is awesome. What converter do you have in there that makes it non optimal? If you change to a converter that's setup for what you have you will see a humongous change. Were you icing the intercooler on each run of just going with water? If water did you have a temp on it before / after?
No ice in the water tank, just 50/50 water antifreeze, I checked the water after the pulls,it was not even warm. IAT's were 60-65*, outside temps were around 55*. I am very happy with the I/C setup. 2 core custom I/C, Ron Davis front mount heat exchanger, 7.6 gallon water tank mounted in the rear hatch, and a Mezeire WP136 pump.
I know you guys are video hungry and I had the guys at work get this loaded up for Chris so i will post up the link! Hope ya don't mind Chris!!!
Video doesn't do this beast Justice.. it is intimidating as hell in person on the DYNO.. especially standing next to it watching the laptop..lol
Chris
http://videos.streetfire.net/video/8...-Am_205818.htm
Chris
#35
Um, you are running a converter from Jegs? That thing may be designed for 500hp. Contact PTC.
Very nice numbers though! I have a feeling that was pretty comparable to our setup number wise but we never dyno'd it with the GT47-88 (or at all for that matter).
#36
No it is a heavy duty TCI part number 242200, that i quoted the description from Jegs. It is not your average Street Fighter stall or anything. It is definitely not the hot ticket for turbo, but the custom converter will follow the new 9" etc...
