comp 26120 springs on ls1?? 3 bar map?
car is 2000 z28
just curious if i can use some comp cams Part #26120 valve springs on an ls1? we interchange these with the ls6 and comp 918s on gtp heads all the time. i have a set of these with less than 500 miles i got off my stage 4 gtp heads which are grand prix heads running ls1 valves but shhh dont tell its supposed to be like some top secret **** i guess. found that out when i was at ET performance(5 minutes from my house) getting them flow tested. the springs are .150 wider on the base than the 918s.
im in the process of building a truck manifold setup been able to do direct swap on most of the parts that were in my gtp, injectors, fuel pump(walbro), guages of course, FPR and so on.
my next question i have the autometer digital boost that came with the same mapsensor design that my gtp had its tied into the vacuum lines couldnt i just cut the wires to the ls1 map sensor and splice them into the 3 bar prior to having the car tuned?? instead of having to buy the cobalt map sensor.
