Procharger install
Old Jan 2, 2009 | 05:43 PM
WS6Drop's Avatar
Default Procharger install
I am installing this kit that I bought off a member here. It looks to me that the label is on the opposite side of all the other p1sc1 that I see on here. The oil drain is not on the bottom and the label is not facing up. Is the clocking off? I called procharger and they said the headunit is for a Ls1 vette so it should work. Here is the link for the pics.
https://ls1tech.com/forums/lsx-parts...-kit-sale.html
This is really frustrating...
Old Jan 2, 2009 | 06:00 PM
MadIceV8's Avatar
Customizing Director
Here's a photo of mine if it helps. It does appear that yours is upside down. The LS1 Corvette is clocked different then the LS1 F-body.
Old Jan 2, 2009 | 06:16 PM
TS6's Avatar
TS6
Post some pics so we can see.
Old Jan 2, 2009 | 08:26 PM
MadIceV8's Avatar
... he posted a link with pictures...
Old Jan 2, 2009 | 08:56 PM
TS6's Avatar
TS6
Yeah, but those pics suck and don't show much of the blower or what particular type of problem he's having.
Old Jan 2, 2009 | 10:45 PM
WS6Drop's Avatar
The problem I am having if you look at MadIceV8's pic my label is located on the opposite side of his. This makes me think the clocking is incorrect. According to EPP's clocking guide the vette and F-bod chargers are clocked the same. When I called procharger they told me my headunit is for an LS1 vette so I dont understand what could of happened.
Old Jan 2, 2009 | 11:07 PM
WS6Drop's Avatar
Default Procharger Pics
Here are some pictures of the procharger...
Attached Thumbnails Procharger install-dscn0423.jpg   Procharger install-dscn0424.jpg   Procharger install-dscn0425.jpg
Old Jan 3, 2009 | 06:15 AM
EPP's Avatar
EPP
The rotation of the Corvette and the F Body blowers are indeed the same. The bolts around the perimeter can be loosened up to rotate the outlet to where it needs to be properly positioned. Was the blower sent back to ProCharger to have it inspected or rebuilt by the previous owner before you purchased it? ProCharger reclocks the blowers to install them on their testing machine, and they don't all get reclocked (repositioned) to where they will fit when they are sent back. I have received a lot of calls from ProCharger customers asking why the blower doesn't fit, when this is the problem. Bob
Old Jan 3, 2009 | 06:36 AM
WS6Drop's Avatar
Thanks for the response Bob, I bought a lot of stuff from you guys for the 8 rib conversion. I was told the blower was new so I dont think it was ever sent to Procharger. I know the outlet can be rotated but I was concerned that the oiling will be not be correct because the label says it needs to be facing up. The label is opposite side and i dont know if this makes a difference, but the blower fits fine in the bracket.
Old Jan 3, 2009 | 06:51 AM
EPP's Avatar
EPP
Question
The drain needs to be at the bottom so that the oil slinger works correctly. Something here is wrong, I just can't place my finger on it. Bob
Old Jan 3, 2009 | 06:59 AM
EPP's Avatar
EPP
http://www.ls1.com/ed/procharger_owners_manual.pdf
Check to see that you have everything installed the same as how it is on page 22 of the above link. Bob
Old Jan 3, 2009 | 07:06 AM
forcd ind's Avatar
not sure what kind of car your working on, but on a self contained procharger, the drain plug has to be at 6 o'clock for the oil pump to work correctly-i use a vette setup on my chevelle, and the name tag is upside down, not sure why they do that, i guess their all put on the same way and when the housing gets rev for the vettes thats how it is
i looked at the add, didnt see where it stated what kind of car the s/c was for? from the serial #, Procharger should know what kind of setup its for, having said that, i have gotten them setup wrong
Old Jan 3, 2009 | 07:40 AM
WS6Drop's Avatar
I check my setup with page 22 and it looks the same.
forcd ind I called procharger and they told the blower is for an ls1 vette
Old Jan 3, 2009 | 09:58 AM
TS6's Avatar
TS6
I'm not seeing a problem? If you're using the procharger J bracket it should position your drain correctly, and you'll just need to clock the volute to fit your needs.
Old Jan 3, 2009 | 02:45 PM
WS6Drop's Avatar
The problem is the J-bracket will not position the drain correctly, its way off to the side.
