project tin can shootin for 9's
Old Aug 23, 2009 | 10:16 AM
  #341
Taubr Unit's Avatar
Hmmm never tried a d1sc before...
what you talkin bout willis?! Sounds like maybe you have some experience with these guys? Willing to fill me in on some stuff
Old Aug 23, 2009 | 01:44 PM
  #342
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've never had an ATI ProCharger. Should be interesting to see what you run with yours.
  #343
robsquikz28's Avatar
Now your doing a D1 what the hell, your always changing setups...
Old Aug 30, 2009 | 12:37 PM
  #344
MelScrilla's Avatar
he changes setups like he changes underwear.........just kidding.
You should have a killer combo either way(lt1,LQ4,turbo,or procharged). I think you need to change to title to tin can shooting for low 9's and maybe even 8's if you get the car light enough.
Old Sep 1, 2009 | 09:22 PM
  #345
Taubr Unit's Avatar
got some work done. Got my master mounted and drilled out the brake pedal etc. Mounted my line lock and ran all new lines. The rear line comes out of the front master, down the frame rail to a union then the stock brake lines runs to the back. The front line runs from the master to the line lock, then from that to the "T" fitting then splits to each caliper....
Old Sep 2, 2009 | 04:30 PM
  #346
Orangepeeler's Avatar
Turned out really nice!
Old Sep 8, 2009 | 02:50 PM
  #347
Turnin20s's Avatar
Car looks good man, I can't wait to start my procharged motor, but I will be staying in the ltx platform as of now. I plan on switching to the LSx coilpacks and computer using the eficonnections setup so I can get rid of the POS opti.
But I'm looking foward to some new progress, I'll be subscribing
Old Sep 19, 2009 | 07:55 PM
  #348
Taubr Unit's Avatar
well finally got everything mocked up. Almost ready...
Old Sep 19, 2009 | 07:58 PM
  #349
flyinZ's Avatar
Damn, put that thing in already. Your killin' me!
And put some air in that damn tire, its flat!
Old Sep 19, 2009 | 08:00 PM
  #350
Taubr Unit's Avatar
**** them tires, lol. its hard enough workin on this ****** piece much less air up the tires!! BTW, u like them rims?? Im pretty sure i bought them off of you, lol.
Old Sep 19, 2009 | 08:49 PM
  #351
studderin's Avatar
brake line look good. I did mine very simalar in my "bitch on a diet" build thread.
One thing my buddy joelster showed me somones setup the ran the passanger side front brake line up high out of the way under the cowl, that way you can take the Kmember off easly. I've been fine going behind the rack like that and thu the Kemeber so far, but that might be a little tricker setup?
Old Sep 20, 2009 | 04:41 AM
  #352
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
^ That is a pretty good idea. I may have to bend mine up like that when I put the engine in.
Old Sep 20, 2009 | 10:00 AM
  #353
flyinZ's Avatar
I hear ya, one project at a time. Otherwise, nothin' gets done.
Yep, they were my old wheels. They look better on your ride though
Old Sep 30, 2009 | 06:43 PM
  #354
Taubr Unit's Avatar
got some more toys in today, poly mounts and my front Aerospace brakes. LEts me say one thing... DAMN AEROSPACE MAKES SOME NICE ****!! Gonna order my rears in the next few days to complete the car in the break department!
Old Sep 30, 2009 | 07:17 PM
  #355
BADHAWK51's Avatar
They look really good I was trying to decide between Aerospace and Strange.
Old Sep 30, 2009 | 07:37 PM
  #356
Taubr Unit's Avatar
i seen a few guys say the Strange stuff was better quality but i dont see how. These brakes are sick!
BTW, hows my old trans holdin up?!?!
Old Sep 30, 2009 | 08:37 PM
  #357
BADHAWK51's Avatar
It's doing good Jerry, I put a Circle D converter in and it hits hard as hell 1.46 for a heavy *** car isn't bad (3550 race weight)but I'm going to loosen it just a little bit more to try to get the car to go bottom 1.4's maybe 1.39 on motor. I'm going to be changing the cam also hoping to go 10.6's at this weight on motor.
BTW I need to let you have the car for a couple days and my junk would be running.
Old Sep 30, 2009 | 11:00 PM
  #358
Damn nice brakes Jerry
Old Oct 1, 2009 | 08:32 AM
  #359
CamaroRacing12's Avatar
good stuff man, i've heard race brakes help so much in cutting rotational weight, its ridiculous how much they improve your times.
Old Oct 3, 2009 | 09:23 AM
  #360
JL ws-6's Avatar
Race your car!
I have those same aerospace brakes on my car, and I felt they worked very well, and the weight loss was great IMO.
I'm swapping to the racecraft drop spindles and will be adding 3rd gen strange brakes to the front of my car, I have the same aerospace setup with modified spindles that's coming off my car, the brakes are going for 950 now for the fronts, I'll let mine go for 850 with the spindles (split the shipping cost)
Shoot me a PM
