project tin can shootin for 9's
#761
More progress..
My ac delete panel annoyed me so I made a new one with a intergraded electrical panel. Cut out a new 1/8" aluminum plate for the block off plate, machined some new bungs I helicoiled and welded on. After I made a second plate that bolts to that so I can bolt the block off for good THEN the electrical board can be unbolted easier.
#772
More progress:
Started on all my vacuum lines this week. Started out by making a vacuum block. Got some stock aluminum tube I turned down then drilled out the inside. Next I drilled for 7 ports.. one on bottom for the feed and 3 on each side to support whatever. Welded and smoothed out a top mounting tab and all finished. My boss gave me some 1/4" plastic/bendy quick connect line to do all my fittings SO yes, those big brass fittings will be replaced with quick disconnect fittings.
#778
When you get this thing all done you should bring it out to merrillville to simon sez. IDK how far you are from there but there's a decent group of ppl that meet up there fri. sat. nights.
It's always possible to get a lil street action as well.
