project tin can shootin for 9's
#81
#82
yea i read that, i guess its just a "to each there own" thing here. I just really liked how the TA mounts and ill never have to deal with any problems ever. I just hate doing things twice so now im done. I stand by my decision. And to be a ***, theres a lot of people running FAST times on small tires, why you got such a big tire? Just bustin your ***** man, lol.
#83
#84
lol, id deff. be scared if i seen thoes when i was behind you Well not to mention the cool factor when they look at my "rearend" haha I mean come on, compare our sig. pics, my car looks like a ***** compared to yours! Wish i was thinking when i bought this rear, i would have had it narrowed a inch or 2
Well now im selling my 4l60 in exchange for a th350 build, so theres another almost 50lbs
#93
The car should run pretty good with the 847 cam and nitrous. Get the car workin real good, hopin to spray the car to the mid 10's.
#94
Sounds good, work with what you've got.
Well, I went through my share of 4L60e's so I can understand the switch. It also seems like your trying to squeeze every penny out of your setup which I think is very smart. One thing I am wondering though... I'm assuming you went with the TH350 for being lighter, cheaper to build, easy transbrake, etc. But what I really want to know is what did you find out about parasitic loss of the TH350 vs TH400, 4L60e, and the 4L80e? I have looked around a little bit about parasitic loss of these, but I'm just wondering what you've found on the subject. There must have been a good reason for you to run the TH350 over a TH400, just wondering what nudged you towards the TH350.
-Dustin-
-Dustin-
#95
basically the rule of thumb...
th350--small block
th400--big block
The 350 has a lot lighter internals and doesnt rob as much hp to turn then a th400. There almost 50lbs lighter then a 4l60. And when build right a th350 can handle 1000+hp. SOOO will i ever make 1000+hp?? no, so why take away more hp with a th400 when i can run faster on a th350. ALSO the th350 has a slightely tall 1st gear then a th400 = better 60ft's.
I HAVE EXCERIIIISIZED THE DEEEEMON!!! (Ace Ventura there for ya, lol)
th350--small block
th400--big block
#98
tauber unit i have always admired ur car...and i admire what u are doing now. one day i want to do the same exact thing... but while im in college ima keep her a summer DD... i wish u good luck with the setup and i will def be watching it progress and ur final weigh in and ET's...
good work
good work
