hot side suggestions
Old Jan 8, 2009 | 09:39 PM
svtkilr's Avatar
Default hot side suggestions
I am in the process of doin a turbo build and I am stuck on what route to go with on the hotside piping and I am new to the turbo scene so I need a little help I am looking to make between 850 and 900 hp and wondering if the hotside piping I go with will hold a big role on how much power I can make and how good it spools...
Thanks
Old Jan 9, 2009 | 01:21 PM
svtkilr's Avatar
I know someone has an answer for me....
Old Jan 9, 2009 | 01:27 PM
sevanseriesta's Avatar
What do you want to know about hotside most charge pipes are around 2 1/2 and the bigger the down pipe the better, I would not suggest a 3" charge may be hard to spool the turbo/turbos with that.
Old Jan 9, 2009 | 01:42 PM
Fireball's Avatar
I run 1 3/4" primaries on my headers and 2 1/2 crossover. More than enough for alot of power
Old Jan 9, 2009 | 01:49 PM
frcefed98's Avatar
truck manifolds, 2.5 in crossover, 3.5 + dp
76mm on up for the turbo, T4 or T6 depending on cubes.
Old Jan 9, 2009 | 02:26 PM
svtkilr's Avatar
I've seen a lot of people say that kits are only good for like 600 HP but I think that is cause of the small downpipe so if I was to buy a cheaper hot side than these big money race kits and just have a bigger downpipe built I should be able to make my power level with the right size turbo am I on the right track or is there something I'm missing
Thanks
Old Jan 9, 2009 | 02:28 PM
Just call josh at KYTP. he can help you a lot.
Old Jan 9, 2009 | 03:05 PM
svtkilr's Avatar
Anymore opinions
Thanks guys
