Reliable Daily Driver
Old Jan 16, 2009 | 02:22 AM
js2fst's Avatar
Default Reliable Daily Driver
This car will be driven every day and ran hard. Procharged It is my wifes daily driver, I do not want to rebuild it every 20 k miles. So do I a forged 346 at650 Rwhp area, 370 at 700 rwhp or a 408 and do 750 rwhp?
Old Jan 16, 2009 | 03:16 AM
LustrousWS6's Avatar
I'd say 408 at 700rwhp... hope you've got a lil over $20k laying around to dump into this thing.
Old Jan 16, 2009 | 11:11 PM
js2fst's Avatar
I am not just sitting almost all other parts in place, have a block, heads,timing chain, lifters, rockers, cam, fab 9, ta relocator, full suspension, pro charger upgrade from p-1 to d-1, exhaust, intake, meth, 8 rib, I am trying to do a 4l8oe swap though too. I am burnt on f- body clutches, I know I will not be doing a spec 3+ again, 2 in 10k miles two pressure plates failed.
Old Jan 17, 2009 | 12:18 AM
Josh@KY-Turbo's Avatar
Hell I am building a reliable DD right now.
Stock 2002 LS1 Z28 6spd.
-E-bay Hot side (reworked by me)
-TC78
-TS 38mm WG
-TS52mm BOV
-3" Aluminum Cold side
-Ebay A2W IC
Keeping to stock 57k mile Long Block, 6spd, and 10 bolt rear. The car wont see slicks or much more than a set of 315/35/17 BFG DR's on some heavy *** 17x11 ZR1's.
It is destined to be my DD year round. Shooting for 500rwhp on 93 octane.
Old Jan 17, 2009 | 01:25 AM
js2fst's Avatar
500 rwhp been there doing that right now stock lower, so on borrowed time and just wanting something to be ready for when it goes. 98 k miles and a p-1
Old Jan 17, 2009 | 06:32 AM
Good deal.
Old Jan 17, 2009 | 02:24 PM
cablebandit's Avatar
346....cheap to replace and lighter than iron without the wear of a stroker. you should be able to run that on 93 octane for a LONG time at 650rwhp. Could prolly even get away with a 4l60e if its a nice build
Old Jan 18, 2009 | 01:59 PM
js2fst's Avatar
Cable are thinking the 408 not as reliable then? When does pushing water come in to play?
Old Jan 18, 2009 | 06:09 PM
will01's Avatar
signing up
Old Jan 18, 2009 | 06:31 PM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com...Car.php?car=54
Check out this 346 budget build with a D-1SC at 16 psi. It ran hard on a 2.1 mile road course for several years, and got 28 mpg on a vacation for the owner. Bob
