New intake going on
Old Jan 20, 2009 | 05:52 PM
Silver_TransAm's Avatar
Default New intake going on
Just bought a victor jr intake and low pro elbow from edelbrock and some nice fuel rails. Wanted to try something different. Just thought I'd share.
Old Jan 20, 2009 | 06:39 PM
98Camarod's Avatar
What throttle bodies does that accept? Looks good, what kinda money are we talking for that if you dont mind me asking.
Old Jan 20, 2009 | 06:55 PM
calongo_SS's Avatar
that elbow looks like it's going to be a pretty big restriction.
Old Jan 20, 2009 | 06:57 PM
98Camarod's Avatar
and the other elbow isn't?
Old Jan 20, 2009 | 06:58 PM
Up to a 90mm.
About 550.
Lots cheaper than my fast 90 which i bought as combo with 90mm throttle body for a 1,000.
Sold the fast by itself for 600. So I think I made out ok considering the throttle body goes for about 400.
Old Jan 20, 2009 | 07:00 PM
The elbow is not bad in person at all. Just looks small.
Old Jan 20, 2009 | 07:04 PM
Phil99vette's Avatar
7 Second Club
Can you get a spacer under the elbow? Looks like its going to need some serious fuel correction to get the motor to run right. You're going to have 2 cylinders that are very lean.
Old Jan 20, 2009 | 07:07 PM
Old Jan 20, 2009 | 07:08 PM
I'm pretty sure thats what the divider is for.
Old Jan 20, 2009 | 07:10 PM
98Camarod's Avatar
Does it accept a stock throttle body or is an aftermarket throttle body necessary?
Old Jan 20, 2009 | 07:12 PM
stock should wrk same bolt spread 90mm throttle body.
Old Jan 20, 2009 | 07:34 PM
ninetres's Avatar
+1
Still looks questionable.
Old Jan 20, 2009 | 08:02 PM
I'll find out by this weekend, once I get my y-pipe to stop leaking so I can make boost. (Damn steep store entrances.)
Old Jan 20, 2009 | 09:52 PM
LSx Heaven's Avatar
I like it, I wonder how well it will do, keep me updated, please.
Old Jan 21, 2009 | 08:57 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I think that elbow is going to cause some big problems.
1) That is a tight small bend. That is going to be restriction no question about it.
2) The divider thing looks questionable at best. It might be good for NA applications, but as Phil said it is going to cause some serious fueling issues.
Personally I would rethink it.
Old Jan 21, 2009 | 11:19 AM
Damn kinda starting to get worried. I can aways get a diff elbow if this one does not work as well as i want it to.
Old Jan 21, 2009 | 11:21 AM
Meaning what exactly? Still trying to understand forced induction tuning.
Old Jan 21, 2009 | 11:23 AM
ninetres's Avatar
By "not work as well as I want it to", do you mean melting a few pistons from being much leaner than the others?
Old Jan 21, 2009 | 11:27 AM
Basically. Need an excuse to buy a short block.
No will only run 5psi to start with the new setup and continue to raise it to 12psi while monitoring it closely.
Old Jan 21, 2009 | 11:29 AM
Which 2?
