New to FI ??
Old Jan 26, 2009 | 09:03 PM
josepy121380's Avatar
Default New to FI ??
Just bought a p1sc procharger. My current cam is 237/242 .600 Is this too big? If so what would be a better one to run?
Old Jan 26, 2009 | 09:10 PM
GrandmasterCow's Avatar
search ... lol
Old Jan 26, 2009 | 09:13 PM
Originally Posted by GrandmasterCow
search ... lol
I did. Didnt come up with much. If your not going to give a real answer please do not respond.
Old Jan 26, 2009 | 09:20 PM
PM Bob@EPP he'll help you out with a good blower cam
Old Jan 27, 2009 | 01:47 AM
Johnv's Avatar
Try what you've got first, nothing to lose !
Old Jan 27, 2009 | 08:39 AM
Well the motor is coming out to do some other things and I figured that would be the best time and easiest to swap the cam. I will have to do some more reading.
Old Jan 27, 2009 | 09:59 AM
ls1290's Avatar
Dumb Ass Vette Moderator
If you are pulling the motor, then that is a great time for a cam swap. It is pointless to comment on the current cam without knowing more details of your setup.
Old Jan 27, 2009 | 10:09 AM
Car has Longtubes, Ory and hooker CB.
Moser 12 bolt with 3.73's
237/242 .600 lunati cam.
Double valve springs.
Thats about it.
Some motor work is being done to support the Procharger. Making it stronger.
Just bought P1SC procharger. 8 rib setup.
Only looking for 550-600 ponies.
Old Jan 27, 2009 | 10:14 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Define "some motor work"... CR? forged? displacement???
Im using the speed inc SC2 cam and have had good results with it. Its spec'd at 224/232 .581/.595 @ 114+2
Old Jan 27, 2009 | 10:20 AM
Same cubes. Forged. That is all. Dont know what CR is.
Old Jan 27, 2009 | 10:53 AM
ChevyChad's Avatar
compression ratio
Old Jan 27, 2009 | 10:55 AM
compression ratio
Whatever stock is.
Old Jan 27, 2009 | 07:18 PM
EPP's Avatar
EPP
Thanks! If the lsa of your cam is a 112 with your lift and duration are, you would be better off with a more blower friendly cam. That P-1SC would have to be spun really hard to make up for a cam that bleeds off a lot of boost. Bob
Old Jan 28, 2009 | 02:58 PM
Suggest a more blower friendly cam. My specs are in the thread.
Old Jan 28, 2009 | 03:27 PM
WHPLASH's Avatar
115 lsa+
Old Jan 28, 2009 | 03:39 PM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=679 Bob
