need help with IAT sensor
Old Jan 30, 2009 | 06:38 PM
koolaid_kid's Avatar
You can probably borrow a kit from Autozone. Their rental program is pretty nice for tools you only need occasionally. Just be sure to use plenty of lube on the tap and go slowly. It's not difficult.
Old Jan 30, 2009 | 06:42 PM
Camaro Jearmy's Avatar
yea, i might have to do that. Thanks again for the help. With this sensor not plugged in to anything, would it maybe cause it to cut out between 5-6k ?
Old Jan 30, 2009 | 08:19 PM
That is a good question. Your PCM uses 4 sensors to measure and adjust fuel mixture: MAF, IAT, and your 2 O2s. Perhaps more stuff as well, but those are the key sensors according to the info I found.
Since it is missing one of the sensors, it may be going into SD mode, IDK.
In the meantime, you can plug the sensor into the connector and ziptie it to the radiator. The reading won't be accurate, but it will get rid of your code (if it is one of those codes that goes away after 3 or so successful runs) and it will start to make more accurate adjustments.
Old Feb 4, 2009 | 05:27 PM
just in case anyone else needs to know...i called pro charger today, they said buy the factory sensor, and take the sensor itself out of the push in grommet and it will go in the plastic screw in piece that comes with the pro charger kit, which threads in the hole. Saves having to tap it.
