need help with IAT sensor
Old Jan 29, 2009 | 06:42 PM
Camaro Jearmy's Avatar
Default need help with IAT sensor
I just got a 97z that has a p600b kit on it. The IAT sensor is not there. It throws the code for it. The elbow is threaded, the sensor that the parts store showed me thats supposed to go in it is not made for a threaded hole. I have the plug in and everthing, just no sensor. I was wondering if someone with similar set up knows what to do? THanks!
Old Jan 29, 2009 | 07:08 PM
98Camarod's Avatar
Get it for a 92 gmc syclone if its the same as the iat plug in for the ls1.
Old Jan 29, 2009 | 07:24 PM
awesome, i'll try it. As long as the plug goes in it, it should work right?!?
Old Jan 29, 2009 | 07:28 PM
98Camarod's Avatar
just get them to get both of them out, the original one for your car and the threaded one from the syclone. They are around 15 bucks, so don't let them shaft you. The are 3/8 npt so make sure thats what the bung is.
Old Jan 29, 2009 | 07:37 PM
sounds great, thanks for the help!
Old Jan 29, 2009 | 07:40 PM
98Camarod's Avatar
no problem, hope it works
Old Jan 29, 2009 | 08:30 PM
eviltwin_1987's Avatar
if they cant find the syclone in 92 have them look in 91. most places dont list them for 92
Old Jan 30, 2009 | 04:41 AM
98Camarod's Avatar
They list it as air charge temperature sensor or something retarded like that.
Old Jan 30, 2009 | 05:27 AM
EPP's Avatar
EPP
Thumbs up
This is what makes this site so great, a lot of good info and people helping other people out! Bob
Old Jan 30, 2009 | 08:13 AM
Thats exactly right. Thanks again for everything.
Old Jan 30, 2009 | 11:42 AM
got the sensor today, its the right plug, looks like the thread is 1/2" rather then 3/8. Im going to try it, if its too big, would there be anything wrong with an adapter?
Old Jan 30, 2009 | 12:31 PM
koolaid_kid's Avatar
So you are saying that the sensor has 1/2" threads and the elbow has 3/8" threads?
The main thing is to insure that the sensor tip gets in the airflow. If the adapter is to long, it will prevent the sensor from being in the airflow, and will provide inaccurate readings.
Your other choice would be to retap the elbow.
Old Jan 30, 2009 | 01:58 PM
thats what i was thinking. I dont know if there would be anything else that requires the same sensor but 3/8" thread? It just had a hollow plastic piece in it, it has the clip for the plug and everything, just nothing inside of it.
Old Jan 30, 2009 | 02:06 PM
also, they are calling it an Air Charge Sensor, i just wanted to make sure this wouldn't change it, i mean the plug in is the same. thanks!
Old Jan 30, 2009 | 02:09 PM
Frost's Avatar
Is this the animal here?: http://www.lsxtune.com/shop/product_...roducts_id/400
Old Jan 30, 2009 | 02:12 PM
should definitely be 3/8 npt
Old Jan 30, 2009 | 03:04 PM
Originally Posted by Frost
That looks better; I may pick one of those up for my car.
Old Jan 30, 2009 | 04:57 PM
looks just like the sensor i bought today, the hole in the elbow is definitely smaller. So tap and die?
Old Jan 30, 2009 | 05:12 PM
98Camarod's Avatar
I had to tap mine, its just a 3/8 npt. Make sure you get all the debris out.
Old Jan 30, 2009 | 05:17 PM
sounds good, i'll try to find somewhere to buy a pipe thread tap. Thanks
