Rear mount guys: Header wrap?
http://www.grandamgt.com/forum/showthread.php?t=75497
Don't forget to get a turbo blanket also! Big difference in spool time!
My first build with dual exhaust I did one front to back and the other rear to front. The one I did front to rear needed re-doing after 2 years while the other was nice and tight.
Latest duals with a layer of ceramic batting under the wrap:
Jim
Jim
Just my $0.02
The wind thing is a valid point
irun4cops,
the a/r you decide on has many factors. With a rear mount one of the biggest factors i've seen is in the transmission type. Stick shifts tend to make less usable power on the larger turbos with rear mounts so i'd personally stick with the smaller a/r like .81 for the 600 rwhp range.
You DEFINATELY want to wrap or coat the exhaust, it makes a VERY big difference in how the car drives.
I personally just upgraded my 1.00 a/r 83mm turbine 80mm compressor wheel to a 1.25 a/r 87mm turbine with the same 80mm and the higher flowing race cover. I'll be doing a write up on my findings in a few weeks after I get it installed next week. My current setup works very good and has just enough lag to get traction on the street.
do you have anymore pics of your setup DeltaT? is it single or twin turbo? did you notice much of a difference with the balance pipe?
Zombie: is you 6 liter completely forged or just pistons and rods, i forgot.
thanks again, Mark
