What is better? Turbocharged or Supercharged?
Someone please help me decide. Will I be able to achieve 8psi with a turbo? Can I run my nitrous system with a turbo or supercharger if I cut it back to 25 or 50 hp shot? If I put a good 3500 stall in my car will the turbo be spooled up when I leave the line?
I don't think anyone really wants to have this debate again. Use the search button and go back a couple of months. You'll find plenty of opinions.
SC-
Let us know how this turns out!!
Vortech Supercharger
-Has always come with 8 rib crank and blower pulleys
-Proven to make 425-500rwhp with stock motor
-Rare complaints about quality or fitment of parts
-Don't have to remove the blower to change the belt like ATI kit
-My friend went 11.1@123mph with a kit, slicks, headers, 4000 stall, and some weight reduction
QMP Turbo System
-Only single turbo on the market
-Significant R&D behind product
-Easiest turbo system to install
-Friends have gone over 122mph with stock motor
Those are my choices.
I drive this car from Odessa Texas to New Orleans once a week. Thats 800 miles one way every week. So I like to play on the run too.
So I guess I am just wondering wich of the two will make more power at the lower RPM, if they are both set up to make 8 to 9 psi on the top end?
. SO the only other place I can think of right now is in the bottom of the trunk. But I still use it for my T Tops. Like I was saying earlier, I drive this car cross country every week. I want all the origanal equipment in it. If I have to move my batterie someplace else to install the Vortec, well that just makes things worst. I could loose the Nitros system all together. But I payed 1300 dollars for the whole system and I haven't had it for a whole year yet. I would hait to get rid of it. I am hopeing to at least use a 25 to 50 hourse boost from it. Thats the main reason I am kind of shunning away from the Vortech Kit. Now I have no idea if I realy have to move the batterie or not. Maybe someone on here can tell me the rest of the story on that part of it. As for the turbo you were talking about, were do I find it and info on it? I do like the idea of a turbo. I would go that route if it will make the same power running down the road that the supercharger makes. Wont there be a lag time or something like that?
even at non-intercooled, the turbo made more avg torque AND peak torque.
no loss of power from a belt like a supercharger either. same went for avg hp..the Centrifugal made more peak hp, since the turbo wasn't intercooled in this comparison. however the turbo made more power al the way until 5k rpm.
superchargers depend on rpm for power, unlike turbos.
as far as efficiency, well it's not even close..think of the millions of turbodiesel trucks that rack up upwards of half a million miles.
yeah top fuel use superchargers..only because turbos are not allowed, eaton type blowers are significantly inferior as well.
NOW:
for mild power a vortech seems to be the ticket..if u own an ls1.
a properly tuned turbo will beat a properly tuned s/c always but sadly turboing our engines is a commitment of patience and u have to be ready for problems to come up.
of course think of it this way..once u get the s/c, u might still be wondering/hoping u had gotten the turbo- and once your turbo runs properly u will not want to go back.
As you ease onto the throttle from a cruise the converter will unlock and downshift much more than stock and put @ 4300+rpms and into the 5psi boost area with the ATI. It will break the tires loose @ a 75mph roll on. With a turbo this would be even more fun, more boost at a lower RPM.
Jeremy Formato
convincing? At 4,000 rpm, the turbo was more than 100 lb-ft. stronger than either the Roots or centrifugal."
- Battle of the Boost, Hotrod Magazine, August 2003.
