Don't lose your spot on the Boosted List
Moderator
I need more than just ET if you want to get on the list... one of the list's purposes is to let people know what is making the kinds of runs that you do. The legend for info is at the bottom of the list.
Here's an example:
Black Ls1 T/A
ET: 11.14 @ 122.68 MPH, 1.67 60'
ATI Procharger D-1SC, 8 PSI Boost
GWP 422 Borer/Stroker
9.5:1 Low Compression, Heads/Cam
PY3400 Stall
Mark Williams 3.73, 12-Bolt Rearend
28 x 11.5 x 16 M/T ET Streets
Weight 4000 lbs
MAC Headers/ORP
526 RWHP / 651 RWTQ, Sea Level, NC
The more you jumble up the info when you tell us all about it, the longer it takes for me to get to fixing it right to put up. ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
The FIRST thing to give is your alias. Someone tell me the Ls1Tech handle/alias for Ron (the guy 427 wanted put in the top spot). I don't care that he doesn't post a lot, but he must be a member of LS1Tech to rank the list.
Thanks!
Here's an example:
Black Ls1 T/A
PY3400 Stall
Weight 4000 lbs
MAC Headers/ORP
Thanks!
