Finaly my OFI build
Old Feb 14, 2009 | 06:56 PM
JerikSS's Avatar
Default Finaly my OFI build
I have installed the passenger side header and installing the downpipe. I am having issues with the driver side header Its hard to get in there and its touching the fuel line. I will see what I can do tomorrow. Did everyone with this kit have this issue?
Old Feb 14, 2009 | 07:01 PM
98transguy's Avatar
what size downpipe ?and turbo size being used?t6 or t4 flange?
Old Feb 14, 2009 | 08:45 PM
ALTRDTA's Avatar
What Heads do you have? If they are ETP's that is your problem! You'll have to either cut the one primary that is hitting off and have it repositioned or just flatten it a little bit. There was a lot of talk about this back when people were installing his kit...
Old Feb 14, 2009 | 09:10 PM
JerikSS's Avatar
I have regular 317 heads. Its a t4 flange. Was the fuel line an issue too.
Old Feb 14, 2009 | 11:10 PM
Andy02Z's Avatar
Default fuel line
Mine touched the fuel line with stock heads.
Old Feb 15, 2009 | 01:05 AM
TurboZ28408's Avatar
ok. youll need to bend the stock fuel lines backwards or get some compression tube flares that flare and make a hardline fitting from the bottom of the chassis.
second. to install you need to remove your steering shaft and install from the bottom
Old Feb 15, 2009 | 01:22 AM
JerikSS's Avatar
I removed the power stearing pulley. It goes in from the front but the fuel line gets in the way. What do u mean bend it backwards? I am a little scared with the fuel line. How do u bend it backwards? Does anyone have pics? Thanks.
Old Feb 15, 2009 | 03:06 AM
i acutally just replaced them, i cut the stock ones from the hardline under the chassis and installed some tube fittings and made all new AN lines to the rail with some fittings
take some tube cutters
-6an AN to TUBE fittings such as seen here
http://store.summitracing.com/egnsea...115+4294847275
some -6an hose and new fittings for the fuel rail
http://store.summitracing.com/egnsea...5&Nao=10#rstop
Old Feb 15, 2009 | 10:44 AM
JerikSS's Avatar
Is there a step by step on how to do that somewhere. I have never delt with fuel lines, or somewhere I can buy an extension for my current fuel line.
Old Feb 15, 2009 | 04:44 PM
nope.
do a search online .. im sure theres how to's everywhere
the first tool you clamp onto your fuel line and make ti go round and round and slowly tighten and itll crimp/cut off the tube
you take the 2nd fitting, ( theres instructions) slide one end on, then the brass ferrule that will crush, and then line it up and tighten it down, it will naturally compress and flare and create a leak free fitting.
then the AN fitting and the line there are how to's online on how to assemble them
Old Feb 16, 2009 | 06:13 AM
98transguy's Avatar
are u going to try and use the 42lb injectors that u have?U are going to run out of fuel.Depending on your goals , u should think about doing a complete fuel system with stainless lines then u can route the fuel lines wherever u want
Old Feb 16, 2009 | 12:13 PM
JerikSS's Avatar
I am going to sell my injectors and buy new ones. I already changed my fuel pump. I am looking to make 550hp/550tq. I just need to fix this problem cheaply. I am kind of in a hurry. Any other suggestions or a how to somewhere to make your own lines.
Old Feb 16, 2009 | 08:10 PM
Alex in Houston's Avatar
Not only did turboz28408 tell you what you needed, he even provided links to said parts. As if that weren't enough, he took the time to type out a simple to follow "How-To."
Man, now you're looking for a "cheaper" (and using that word in relation to turbocharging a car is recipe for disaster) alternative?!
Old Feb 16, 2009 | 10:07 PM
i made 649 WHP 669 tq on a single racetronix in-tank pump on a 98 ( uses higher fuel pressure from the get go) and some mototron 60 lb injectors
those 42's wont cut it
Old Feb 16, 2009 | 10:17 PM
JerikSS's Avatar
thank you for your help turbo......that a lot of power. Ill try it like that....I just dont feel comfortable making my own lines.
