Custom Intercooler?
Old Feb 20, 2009 | 06:16 PM
hefftone's Avatar
From: Dallas, Ga (2.7 miles from Southeastern Dragway)
Default Custom Intercooler?
I'm looking for an intercooler like depicted in this incredible MS Paint mad skills effort. Height is sorta limited, so the typical single side with vertical core is no dice. The 180º u turn may create some flow problems,.... but hey that's somebody elses job to figure out. May seem strange, but would be easier to mount and easier i/c pipes.
Ever seen one, or recomend somebody?
Old Feb 20, 2009 | 06:30 PM
elias_799's Avatar
if you have space limitations get an air to water intercooler. good luck.
Old Feb 20, 2009 | 06:37 PM
ls1_chevelle's Avatar
PM sent to you.
Old Feb 20, 2009 | 11:16 PM
DeltaT's Avatar
You really, really don't want something as restrictive and low flowing as that. The air path available to the hot charge would limit the IC to something in the 325-450cfm range, before you add the u-turn into the mix.
Jim
Old Feb 21, 2009 | 01:27 AM
engineermike's Avatar
It looks pretty restrictive. But, for custom intercoolers, call Bell. They built mine and it's top quality. Whatever size and shape you want.
Old Feb 21, 2009 | 10:33 AM
turbocuda's Avatar
Someone else's job...OK.....if someone builds it for you don't complain when it has subpar performance.....can't change physics.
Old Feb 21, 2009 | 10:46 AM
themachasy's Avatar
x2, check bell's site. They can make any core you want with any endtank configuration.
Old Feb 21, 2009 | 12:00 PM
Gauge's Avatar
11Second Club
+1 for Bell. I would have gone that way had I not found a universal intercooler that met my needs.
Old Feb 21, 2009 | 12:10 PM
SD99TA214's Avatar
i say go for it. you never know what might happen. its hard to say if it will or will not be restrictive. or efficiant for that matter. hell you would think restricting a garden hose with your thumb would hurt, as a result, you get the same flow with more velocity, .....to a certain point then it chokes off. so try it. like i said ,ya never know.
Old Feb 23, 2009 | 01:02 AM
DeltaT's Avatar
No, that's not true. The charge flow area is easily calculated and results in a cfm rating for a given intercooler design at a certain pressure drop.
Forget about the U-turn part of that IC setup, and then it just looks like a really long IC with a small charge flow area and a huge crossflow (cooling) surface. It will have high charge heat rejection, which is good. But it will have a tiny charge flow area which is bad, and it will have really long passages which add drag, also bad.
This idea might work on a Honda that didn't need a lot of total air flow, but on a V8 under boost that needs roughly in the 700-1100cfm range (pretty common) it is a crappy idea that will choke the entire setup.
Call Gerhart (IIRC) at Bell Intercoolers. He helped me get my design perfect. They are pricey but if you really need a custom they are IMHO the best and best priced.
Jim
Old Feb 23, 2009 | 08:26 AM
ls1290's Avatar
Dumb Ass Vette Moderator
As others have stated, the 180 bend in the IC would be a huge restriction. Typically you want to have a few bends as possible and when you need a bend, try to keep it to 90 degrees or less.
Old Feb 26, 2009 | 03:20 AM
SD99TA214's Avatar
Jim
you make some valid points, not tring to be a smart a$$ i swear but your talking like you went to this dudes house and took measurements of his intercooler....... haha man we dont know how big or how small it is.......in his own words he said not to judge the draft. it doesnt exist so how do you know what it will or wont flow?? like i said imho try it....... someone had to eat the first egg......and hell if it works for hondas, make your paper.
Old Feb 26, 2009 | 06:32 AM
chuntington101's Avatar
Hetftone, can you tell me the advantages of this design over a conventional left to right design? basically whats the need to the 180 degree bend?
the reason i ask is because you are effectively halving the flow rate of the overall core by doing this.
Cheers
Chris.
Old Feb 26, 2009 | 12:31 PM
SD99TA214's Avatar
valid question!
Old Feb 27, 2009 | 02:17 AM
Originally Posted by SD99TA214
valid question!
thanks, not trying to be an *** or anything, just trying to figure out the requirements for his system. if this is the best he can use then thats it. however there maybe better ways to do it.
plus i really like these threads as it gets you thinking outside the box a little.
Chris.
