Switching to Speed Density
Old Mar 4, 2009 | 06:15 PM
  #41
98Camarod's Avatar
No, I took it off, but taking the old one out could be done with it on if you have small enough arms. You can try it with it on, and if you can't get then you just have to take it off.
Old Mar 4, 2009 | 06:21 PM
  #42
barnat's Avatar
Originally Posted by Pat-Man
Those that switched, were you able to get the old MAP sensor out without taking the intake off? Seems like it is possible. I can actually get my skinny arm back there, just not sure if you have to pry it off, or just twist a certain way and pull it off.
LOL!!This is why i was just going to leave the stock one in the intake and take the wires and plug into an extention and route up to my custom made vac manifold !
If anyone knows where i can buy a longer extention wire let me know. Im talking about the stock wire that plugs into the map sensor itself from the stock harness! is the one ill need longer , then ill plug the adapter wire into that for the 2 bar map sensor!
Old Mar 5, 2009 | 11:10 AM
  #43
bumpin_records's Avatar
when you change to SD that eleminate mass air flow sensor right?
Old Mar 5, 2009 | 11:34 AM
  #44
ddnspider's Avatar
correct.
Old Mar 10, 2009 | 09:54 PM
  #45
barnat's Avatar
So,Im guessing if im changing to the 2 bar, I can leave my stock map in there on the back of the intake with no problems??? as a plug?? so to speak! and run an extention wire from that stock plug up to where ever i decide on mounting my new 2 bar? Im just thinking why pull the intake for a sensor im never gonna use again that allready in place as a plug!
Old Mar 10, 2009 | 10:01 PM
  #46
nastychevelle's Avatar
saturn ion map's are 2.5 bar
Old Mar 10, 2009 | 10:14 PM
  #47
chevyz2801's Avatar
i cant find any info on speed density where is the sticky or link
Old Mar 11, 2009 | 07:51 PM
  #48
Taubr Unit's Avatar
subscribing
Old Mar 11, 2009 | 08:19 PM
  #49
the judge's Avatar
the #is gm12580698 ac delco#213-1631 you just snip off one mount tab easy to change in the car good luck
Old Mar 12, 2009 | 09:55 AM
  #50
Pat-Man's Avatar
I'm thinking about making a small right up when I change mine out soon. I should be able to get good pics since I'm switching to an LS6 intake at the same time.
Old Mar 14, 2009 | 08:30 PM
  #51
barnat's Avatar
Nobodys said anything about just leaving the stock map in the intake as a plug so to speak if going to a 2 bar and relocating ?? So im guessing its ok? This way i dont have to pull the intake Just unplug from stock map, plug in new extention to where i mount my new 2 bar and im good to go, Right?
Old Mar 14, 2009 | 08:38 PM
  #52
98Camarod's Avatar
Sounds alright to me. You still are going to have to try and get your extension plugged in.
Old Mar 14, 2009 | 09:28 PM
  #53
ddnspider's Avatar
a little common sense goes a way.
Old Mar 14, 2009 | 09:54 PM
  #54
ItsNotStock's Avatar
I believe Katech makes a MAP ext harness. It's made for using the L76 intake manifolds with stock f-body wiring harnesses so it's the length from the rear of the block to the front. Should give plenty of slack if your map sensor is still on the back of the manifold.
Old Mar 14, 2009 | 11:07 PM
  #55
KWIKKAR's Avatar
Whats the differece between a 2 bar and 3 bar. My tuner said go with a 3 bar I beleive.
Old Mar 14, 2009 | 11:26 PM
  #56
vaticano's Avatar
1 bar is 14.7 PSI at sea level this would be regular atmospheric pressure
2 bar is 29.4 PSI or 14.7 psi above atmospheric pressure
3 bar is 44.1 psi or 29.4 psi above atmospheric pressure
Old Mar 25, 2009 | 08:04 AM
  #57
Pat-Man's Avatar
Added pics of the MAP Sensor and how it needs to be modified.
Old Mar 25, 2009 | 10:15 AM
  #58
witry's Avatar
ok so in an earlier replay it was mentioned that the car wouldnt start when they installed the 2bar map sensor is that true on all F-bodys because my car is going to be SD tuned and tomorrow i will be swaping manifolds to and aluminum one and was going to but the cobalt map in and now i dont know if i should because it wont be tuned for another month or so
Old Mar 25, 2009 | 10:22 AM
  #59
Pat-Man's Avatar
Honestly, I'm not sure. I would think it would start, you just wouldn't be able to utilize the sensor's ability to read higher levels. I can't start mine to find out because I swapped in bigger injectors, so mine may start, but won't run for long. Hopefully some of the current SD users can say if I'm wrong or not.
Old Mar 25, 2009 | 02:57 PM
  #60
98Camarod's Avatar
I can say from my own personal experience that having a 2 bar map in a 1 bar tune, my car didn't start. Loaded the 2 bar OS, fired right up.
