harlan 2 step.... will it build boost
Well I got home reset the 2 step to 5K and re-ran the reference for the boost controller to after the throttle body. The car made more boost off the waste gate spring after that but ever since then the 2 step would only make about 1/2 a pound. So I basically made 2 changes and dont know which one affected the 2 step.
OK here is an example. With the Lingenfelter 2 step set at 2800 rpm, it would take 2.8 seconds to get to boost. (2800 in my set up equals 4 pounds)
I changed nothing, except for taking out 8 degreest while on the 2 step, and now it takes 1.2 seconds to get to 4 pounds. (Boost amount is controlled by rpm cutoff, how fast you get there is controlled by timming) At least in my set up.
