Intercooler question!
Old Mar 5, 2009 | 02:34 PM
o2ws8's Avatar
Default Intercooler question!
I had one of my turbos go out and oil made it to the intercooler qhat can I do or use to clean it out!Any suggestions?
Old Mar 5, 2009 | 03:53 PM
1320's Avatar
I ve used gasoline a few times.....put in, slosh around, dump out....repeat. After you think you got clean, blow it out with compressed air and let sit out for awhile.
Old Mar 5, 2009 | 06:01 PM
extremetoy's Avatar
is it common for oil, stuff to build up in it?
Old Mar 5, 2009 | 07:26 PM
HUNTER02SS's Avatar
I wouldn't use gasoline, but I have used a diluted mix of degreaser(purple stuff) and sloshed it around. Is it common, well sometimes it happens. seals go out and other things happen.
Old Mar 5, 2009 | 07:56 PM
hawk584's Avatar
simple green , lots of water and a lot of air dry/ evaporation time
Old Mar 6, 2009 | 06:54 AM
o2ws8's Avatar
Thanks guys!
Old Mar 6, 2009 | 08:39 AM
slow67's Avatar
Gingervitis Addict
I would use Simple Green before the Purple stuff (as in Superclean) as it destroys aluminum if any is left in there.
Old Mar 6, 2009 | 09:21 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I would use some Dawn dish soap. Simple Green is even is corrosive to aluminum.
Old Mar 6, 2009 | 10:44 AM
b00sted's Avatar
Have a radiator shop boil it out. We did that before with a GN intercooler.
Old Mar 6, 2009 | 11:04 AM
vandal0-0's Avatar
Mineral Spirits works good also
Old Mar 6, 2009 | 05:45 PM
DeltaT's Avatar
I also used a little Dawn in warm water, then filled it twice with distilled water and drained. After draining it is ready to use - a little water into your motor won't do anything bad. I like distilled so there's no mineral deposits left.
Gasoline is an unsafe choice and if you backfired afterwards you might blow up something important, like your garage
Jim
