Zombie's "Quick Spool" valve testing with pics and nerd like graphs
Old Mar 10, 2009 | 03:51 AM
  #61
bnio's Avatar
You need a servo to control that valve, then no bleed over at all. It will only open when its suppose to!!
Thats control!!!
It will work for twins also just like they said you are effectively reducing a/r, but you results will depend on initial a/r and turbine size/trims etc.
Old Mar 10, 2009 | 06:56 AM
  #62
TXZ0603's Avatar
Thanks for the info!!!!
Old Mar 10, 2009 | 10:19 AM
  #63
Zombie's Avatar
Thats control!!!
The bleed over happens internally in the housing, nothing you can do about that.
I actually built a servo controller for it with adjustable cracking and opening pressure based off a PIC and a MPX 2.5 bar MAP sensor. I didn't know if the servo would would be able to withstand the temps it would see or not and I really wanted something mechanical due to reliability. I'm a geek and love electronics, but this is something that should follow the KISS principal.
Old Mar 13, 2009 | 01:57 PM
  #64
bnio's Avatar
I am a geek and I also love elctronics, have you tried your servo control yet? This is what I have been planning to do also. I am curious how it worked for. I tend to go with more electronics but also try to have a mechanical back up that I can switch to on the side of the road if necessary. I primarily work with atmel chips right now, its funny I have read some of your posts but haven't seen the the computer/elctronics side till now.
Old Mar 13, 2009 | 03:08 PM
  #65
Zombie's Avatar
I have no plans to try out the servo control right now. It only took me a few hours to develop it as a backup plan in case we couldn't get the actuator to work.
Old Mar 14, 2009 | 09:24 PM
  #66
bnio's Avatar
So in your first post you mentioned that the wastegate actuator was originally to stiff that came with the valve. Is there a specific reason why, or any difference in how to size the wastegate actuator for the valve? Also with the valve actuator are you still using the exhaust wastegate that is still in the system or is it effectively circumvented now?
Andrew
Old Mar 14, 2009 | 10:07 PM
  #67
Zombie's Avatar
you still need a wastegate. I ran this turbo without the valve and was able to spool it perfectly fine. As for the actuator, you just need one that has a very low cracking pressure.
Old Mar 15, 2009 | 02:11 PM
  #68
ericwilloughby's Avatar
On my Holset WH2D: Because it's diesel it came with a 20 psi actuator. I found a 5 psi on eBay for $40. I installed it and realized that 4 psi was as fast as I could spin it anyway. I didn't even need a wastegate. It just depends on the A/R and whether it's a rear or front mount.
When I get one of these I will be trying it on a Holset HX-50 and it will be used not only as A/R control but boost control also.
One of the things I don't like about external wastegates is they sound like ****. It drowns out the spool sound.
Old Mar 20, 2009 | 09:56 AM
  #69
PrformanceMetalWorks's Avatar
Hey Zombie I got your new lever done and will be sending it with the incoming order.
1320 Yours is going out with his.
Old Mar 23, 2009 | 12:32 AM
  #70
Turbo V6 Camaro's Avatar
could yI run this off the line from the top of my WG from my boost controller wouldn't that control both?
Old Mar 23, 2009 | 03:56 PM
  #71
Linxs's Avatar
Not if you are running a lot of boost.
BTW i run this Valve it works great! Great product.
Old Mar 24, 2009 | 12:59 PM
  #72
1320's Avatar
Im gonna do some stress testing of the valve on my cummins soon. I run a compound turboed 5.9 in my truck. We thought it would be a good idea if we tested them in an extreme enviroment. So Im getting a hx40 with a divided 19 cm housing to test withthe valve to see if I can spool it like my hx35 (14cm) . It will also be subjected to 1300 degrees for extended periods towing a 50 ft enclosed trailer.
It should be a good test, and maybe ad some significant hp with the larger exhuast housing. I hope to top 800 on just #2. Time will tell.
Old Mar 24, 2009 | 01:27 PM
  #73
longrange4u's Avatar
Zombie, 1320... you guys are sick!! Hahah As always you are pushing the edge of rear-mounts! I love it! I cant wait untill you guys are pressing one of your cars well into the 9's in Vegas! Keep up the great work!
Old Mar 25, 2009 | 03:20 AM
  #74
chuntington101's Avatar
that is going to test the valve........hope it works well.
Chris.
Old Apr 9, 2009 | 01:28 PM
  #75
DAPSUPRSLO's Avatar
I have a 97 dodge with a 12v cummins and a big single s468 that's got it's eye on your results 1320 so keep me posted!!! I ran some low 12 second passes, best 12.07) last night at 6350lbs and am trying to go faster but being this truck's a drive i'd sure like to spool this single up sooner and would definitely like to do so at the line! It takes a while to get this charger lit on the line with my current converter.
Old Apr 9, 2009 | 11:57 PM
  #76
ZL1Killa's Avatar
i just read this and wow... going to have to investigate some things here, lol. more projects
Old Apr 13, 2009 | 09:33 AM
  #77
1320's Avatar
you need to empty your messages..........
your box is full.
Old Apr 16, 2009 | 07:08 AM
  #78
1320/Zombie have you got any more feedback or test results??
Chris.
Old Apr 16, 2009 | 04:46 PM
  #79
Zombie's Avatar
Chris.
no, track has not been open to street cars for a month. Its supposed to be open tomorrow and I might go.
Old Apr 16, 2009 | 06:33 PM
  #80
1320's Avatar
The car is probably going tomarrow....
keys....check...
car......check...
still need to have a tire fixed....but that can happen somehow in the next 24 hrs.
