heads for boost
Old Mar 10, 2009 | 07:08 PM
KOOSWS6's Avatar
Cool heads for boost
How much boost will the Patriot Heads take (ls6 stage 3). I will be rebuilding a ls1 with low compression with a 72mm turbo.
Old Mar 10, 2009 | 07:15 PM
TurboAv's Avatar
That's still based on a stock GM casting with a 1/4" deck thickness. AFR's, ETP's, Trickflow's, Darts, have thicker decks for lots of boost. 3/4" if I remember correctly. I would think 10-12 would be safe on stock heads would be ok, but after that I would get different heads. Another thing to remember is that the Darts are pretty cheap and have that thick deck. Do a little bowl work and a good valve job and you are into them less than $2g's.
Old Mar 10, 2009 | 07:40 PM
KOOSWS6's Avatar
That helps Thanks
Old Mar 10, 2009 | 07:52 PM
theblur98ss's Avatar
kyle ran 23 or 26lbs through his patriots. I'd keep it lower though to be safe as stated above.
Old Mar 10, 2009 | 07:59 PM
black01_WS6's Avatar
243's and head studs are a must with boost. I wouldn't trust them over 12-15lbs.
Old Mar 10, 2009 | 11:56 PM
elias_799's Avatar
i would get some lq9 heads if you are working on a budget. i would stick with a head that has big combustion chamber, 72cc and up. you want a big combustion chamber because it will prevent knock better then a lower cc head on a same CR motor.
Old Mar 11, 2009 | 01:54 AM
BigRich954RR's Avatar
15 psi on stock head casting here . i have seen 21 psi used on them before but i wouldnt try and stay below 18
Old Mar 11, 2009 | 04:54 AM
EPP's Avatar
EPP
We've run 16 psi quite often with Patriot's stock thickness heads with ATI ProCharger superchargers, and we've never had a problem at that boost level.
This Corvette has seen a brutal environment on a road course with 16 psi of boost and Patriot heads. http://www.exoticperformanceplus.com...Car.php?car=54
Same car now with an F-1C. http://www.exoticperformanceplus.com...Car.php?car=40 Bob
Old Mar 11, 2009 | 05:06 AM
james562's Avatar
Are you still running the patriots with the new blower @18-20lbs?
1/2 ARP studs or OEM size?
What head gaskets?
