Its alive! Fired up the new engine vid
Old Oct 19, 2003 | 10:21 PM
frcefed98's Avatar
Default Its alive! Fired up the new engine vid
Well she starts up and runs. We broke her in today. Car wanted to feel strong but the damn belt is still slipping like mad
But all the long hours toiling away in the driveway finally paid off
http://home.comcast.net/~jsbird98/newengine.mov
(9.6megs)
How does she sound?
J
Old Oct 19, 2003 | 10:51 PM
1dirtyZ's Avatar
Default Re: Its alive! Fired up the new engine vid
very pissed off!
Old Oct 20, 2003 | 12:02 AM
frcefed98's Avatar
Thanks Dirty, I don't know if the PCM is still learning or how long it takes to relearn things but I am having problems with it idling after I come to a stop when its at operating temp. It dies after I stop. My old tune for the B1 stock LS1 didn't do this at all. The battery was a little dead so I stuck it on the charger to see if this helps any. If not then I will check to all s/c hoses and the intake to see if I don't have a leak somewhere.
J
Old Oct 20, 2003 | 12:13 AM
1dirtyZ's Avatar
try raising the idle 100 rpm's or so. or just adjust the idle screw up a bit.
Old Oct 20, 2003 | 12:36 AM
BIGBOS's Avatar
What kind of cam do you have in there, it sounds good....I'm looking for more ideas on what to upgrade to in the future....
Old Oct 20, 2003 | 01:04 AM
frcefed98's Avatar
A cam that will be perfect size wise for a 372 CID beast like yours. Check your PMs*EDIT* your email
Dirty, I'm going to ATAP it tomorrow to see where the idle is at(mail order tune). If its too low, I will adjust the screw to see what happens.
Thanks,
J
Old Oct 20, 2003 | 01:11 AM
maddboost's Avatar
Nice to see you got the new engine running frcefed98. Now when in the hell are you gonna get ride of that 10 bolt? I think ive decided on my new motor, im probably gonna go with a 408 stroker and some spray later on down the line. I miss having a FI car which was my last one, but seems to be too many problems with these FI LS1s and frankly I dont have the money right now.
Old Oct 20, 2003 | 01:15 AM
BIGBOS's Avatar
Will do..
Thanks
Old Oct 20, 2003 | 01:30 AM
frcefed98's Avatar
Bos make that your email I edited my last post
Madd, thanks man, I will get rid of that poor lil 10bolt when it shoots both axles out on the ground. I was running ET drags on it 2 weeks before the engine tear down and it was holding its own 60ft were in the 1.59 range. I hear ya on the FI problems. I hate the belt slip this ATI kit has. I think I have it nailed though. I found the perfect sized belt that is in pre-stretch mode in the garage now. It barely fits the MMS CP and the 3.2 s/c pulley. So slip should be limited with this thing. I'll post up if the pre-stretch tool I fabbed up did the trick.
J
Old Oct 20, 2003 | 08:03 AM
Noyzee's Avatar
8 second mod
What size is the new motor, I saw pics, but my 100year old computer wont dowload the vid, It looks damn good tho!!!!
Old Oct 20, 2003 | 05:10 PM
frcefed98's Avatar
Noyzee, thanks man, its a 348. Nothing crazy ci wise. I just hope it makes some power and outdoes the stock LS1 B1 cam'ed, stock headed bullet it is replacing. We will see, just have to get the belt to stop slipping
J
Old Oct 21, 2003 | 03:48 AM
Ryan23silverado's Avatar
AHH soundin' gooood! What is your compression ratio and how much boost do you plan to feed her? btw that flaming skull is SWEET!!
Old Oct 21, 2003 | 07:24 PM
frcefed98's Avatar
Thanks Ryan, compression ratio should be @9.1-1. I hope to get 15psi when the belts cooperate with the pulleys they are suppose to be riding on.lol
J
Old Oct 21, 2003 | 07:44 PM
BIGBOS's Avatar
I know your running a 3.2" blower pulley, what size crank pulley are you running?
Old Oct 21, 2003 | 10:33 PM
Jammer's Avatar
That thing does sound PISSED as Dirty says. Nice work and congrats. Keep us updated.
Noyzee, give up just one mod and buy yourself a new PC, your missin out on this one. On second thought, dont give up any mods, what the hell am I thinking.
BIGBOS, stop thinking about the future for a second and let some of us catch up!
Old Oct 22, 2003 | 01:15 AM
BIGBOS's Avatar
I've been trying to catch up all summer, and my procharger setup still isn't right....
Old Oct 22, 2003 | 07:49 AM
Noyzee's Avatar
8 second mod
Skip a mod for a stupid computer!!!!!!!! Come on now, I use my coputer for about 10 min a day, and its only to come on ls1tech. I will see the vidio from work, it just has to wait till no one is around. Now dont ever ask me to do that again!! j/k
FRC----That thing should rip, Good luck.
Old Oct 22, 2003 | 07:34 PM
frcefed98's Avatar
Bos-I have the MMS CP I can't remember the size to save my life right now I think it is 7.7XX or 7.8XX I'm running a gatorback 4060395 with the 3.2 pulley. This belt was a bitch to put on I had it "pre-stretching" for two days on the the engine hoist to get the play needed to get the allen headed bolts started in the head unit. I think the belt length is 39.5 inches.
For a 3.3 pulley try a 4060400 (length 40 1/8?)I was running that belt with the 3.4 pulley and the MMS pulley with good results. My advice to you would be buy booth try em both out and see which one fits best and take back the one not needed.
Hope this helps you get some boost showing on that guage. Speaking of gauge when I put my guage on back in the day I had the boost line all messed up and it would only show 2psi, once I fixed my goof it was showing the 6psi my lil powerdyne put out. maybe?
Thanks Jammaster J and Noyzee
UPDATE WE NOW HAVE POWER! The new belt looks to be working wonders. The car has a ton of power off idle now, don't know about topend or where boost is sittiing as I got pulled over when doing the WOT drills on the city streets those damn sneaky motorcycle cops, burnout length 99.6ft=Court Date 11.03.03
J
Old Oct 22, 2003 | 07:41 PM
frcefed98's Avatar
oh yeah cam maker says the car needs to be idling at 950 in gear, not the 850 it's idling at now, PCM has to go back to Ed W. I dont know why he went so low, he had my B1 idling@925?
J
Old Oct 23, 2003 | 01:21 AM
BIGBOS's Avatar
Sounds good that low....
Thanks for those #'s..
I got a carquest belt today, there is a fresh napa on it now that we got everything lined up, I'm gonna see how that does on the dyno tomorrow...
I'm interested in trying a dayco too...
