Track results are in!!!!!
I was chomping at the bit to see what your results would be since our engines are so similar.
I am very impressed to say the least!
Good luck getting the 1/8 mile down with the chassis improvements.
8's are right around the corner!
We have very similar ET goals, but I am cheating a bit by shaving a ton of weight out of the car. I am hoping to be less than 3,200lbs with me in it.
BTW- What did your car weigh at the track?
Jim
Jim
Here is the buildup rundown thread....
https://ls1tech.com/forums/forced-in...ldup-pics.html
If you need anything else, feel free to ask.
That thread was started a while ago, before the car was running. Some stuff has proven to work such as my custom 3 in tank 255 Walbro fuel pumps..
Other stuff like the LS7 head gaskets, did not work out.
Needless to say my goals have been met and surpassed in most areas, and we are starting to see the light, and it is getting fun now.
Just got the car on the lift. Going to install the shocks.
Thanks again for the help, I will update you to the outcome.
Car is bad *** and your engine bay looks like a cluster ****
Hope to have it running next week.
