STS new numbers
Old Mar 23, 2009 | 05:28 PM
Silver_TransAm's Avatar
Default STS new numbers
Well I just got back from getting the car retuned at Nelson Performance after some changes I made to my setup. I knew my limiting factor was my fuel system so thats why I could not push it any further. Next upgrade fuel system and going for 650whp. This run was at 12psi but had to cut it short due to the fuel situation. 537/501
and here is the run.
Old Mar 23, 2009 | 07:06 PM
No comments?
Old Mar 23, 2009 | 07:08 PM
IT_SS's Avatar
looks and sounds good
Old Mar 23, 2009 | 07:25 PM
98Camarod's Avatar
Originally Posted by Silver_TransAm
No comments?
Got a nice torque curve, what was the afr?
Whats your current fuel setup and your future plans?
Old Mar 23, 2009 | 07:30 PM
11.3 afr under boost.
48lb injectors, aftermarket rails, and walbro pump. Next is -10 supply, aeromotive pump and 60lbers with referenced regulator. Out of money for now.
Old Mar 23, 2009 | 07:38 PM
98Camarod's Avatar
I have the referenced regulator and my 42lb injectors duty cycle is at 99% with 11.5 afr.
I need to get 60lbers, -10 supply, and another walbro. I'm broke too, I know the feeling.
What was your IDC?
Old Mar 23, 2009 | 07:46 PM
KnightmareLS1's Avatar
Finally!! A Tune!! Congrats, nice numbers man. Mine should be on the dyno tommorrow, the guy tuning it was gone all last week so car has been sitting Clutch,injectors,and MAP sensor are in though, just waiting on the finishing touches!!
Old Mar 23, 2009 | 07:47 PM
IDC no clue.
Old Mar 23, 2009 | 07:51 PM
98Camarod's Avatar
IDC no clue.
You should have a bit more room with those injectors, but then again, not sure since you don't have the boost ref regulator.
How many bits can you log with your scanner? That would be something to see if you have any room for more power.
Also, did you try and lean it out a bit and see if you made any more power? I know some turbo setups make more power with leaner afr
Old Mar 23, 2009 | 08:05 PM
Awesome man, good luck on some high numbers.
You deserve it after all this time.
Old Mar 23, 2009 | 08:48 PM
OUTLAWZ RACING's Avatar
Sweet bro we should line them up jk LOL! Good afr strong numbers through an ato as well.
Old Mar 23, 2009 | 08:54 PM
All I have is an aeroforce scan gauge that can only do so much since it does not log anything.
We pushed it one time and made about 550-560 but did not want to push it too lean since it is the stock 115k short block. He told me that he thinks we can get 600-650 with a better fuel system. Still running the beefed up 10bolt and it is starting to make noise.
Old Mar 23, 2009 | 08:58 PM
Thanks. Yeah so I could eat your exhaust.
Yeah not bad through the 4l80e and a 10bolt. The 9inch will suck it down once I put one in though. I need to get it to the track before the rear gives up on me to see how much power its making real world.
Old Mar 23, 2009 | 08:59 PM
98Camarod's Avatar
I just assumed you had hp tuners or efi live since you said you tuned it.
I'm livin on the edge with the 10 bolt as well. No beefed upness for me though, just some 4.11 gears which are terrible for turbo setups. I have about 85k on mine.
Next on my list is most likely fueling and then the rear.
Old Mar 23, 2009 | 09:01 PM
Same here, then a forged bottom so I throw some real boost at it. One step at a time I guess.
Old Mar 24, 2009 | 02:14 PM
Karpellarpy's Avatar
how is the spool with the T-76?
Old Mar 24, 2009 | 04:58 PM
Well if you leave soft the rear should live for awhile hell I have harden axels and 373 gears in mine 10 bolt it wines when it gets hot aftera 180 mph stint on the testing grounds. But I wouldnt push it further bro with that power you should see 11's
Old Mar 24, 2009 | 06:35 PM
Spools up good considering I still have longtubes on it. Switching back to manifolds soon.
Old Mar 24, 2009 | 06:38 PM
Mine whins when it gets a little warm too. I just have some 3.42 gears and stiffening TAPerformance cover with some amsoil. I would love to see some mid to low 11s out of it the way it sits. Headed to the SAR soon to find out.
Old Mar 24, 2009 | 07:10 PM
ZL1Killa's Avatar
get that fuel fixed and get back with us on numbers... 12psi, I hope you easily get to 620+
I'm at 423 431 at 5psi no IC
soon to dyno at 5.5psi with my IC.
then I will dyno at 7psi
