View Poll Results: STS 70mm 8 PSI Turbo(IC) VS Procharger D-1SC 8 PSI(IC)?
23.97%
76.03%
Voters: 121. You may not vote on this poll
STS VS Procharger Poll?!!!!!
Old Mar 30, 2009 | 11:06 AM
  #81
Texas Heat's Avatar
Originally Posted by bravoboost
ur car is an exceptionally strong sts car... most sts GTO's dont run like urs, to say the least lol
LOL well I guess we will have to see how the pig does with the new setup.........850+rwhp with my junk *** STS!
Old Mar 30, 2009 | 12:37 PM
  #82
bravoboost's Avatar
We all know ur sts isnt junk (i've seen ur vids) ... LMAO... but ur setup is also far superior to the base STS kit....
Old Mar 30, 2009 | 01:16 PM
  #83
omore001's Avatar
I've driven a friend's D1 auto procharged LT1 at 12 lbs and my STS auto 67mm LS1 at 8 lbs, hands down, the STS LS1 pulls harder and makes me smile more. To me, the procharger felt like it was losing power up top even though the boost climbs to redline. I did love the drivability of the procharger at WOT, it is much more forgiving than when my turbo spools up.
The best advice I could give you is to drive both and see what makes you smile more. If you get an STS kit, try to steer away from the base kit, you can get a much more improved version capable of way more power than a D1. My 2 cents, D1 for a 6-speed daily driver, STS for multi-purpose Automatic.
Old Mar 30, 2009 | 03:42 PM
  #84
BOOSTED00SS's Avatar
Honestly, that whinning at idle on prochargers sickens me. Sounds like sumthing is broken, or perhaps a vacuum line is leaking etc ... IDK
to each is own, with the true duals you barely hear mine so its nots as bad i guess. just not a fan of the STS kit, too many issues, intake under the car, i dont think you could ever drive in the rain, oiling system, plus thats alot of pipe to fill with boost, and that stuff hangs down kinda low on stock suspension, i prefer the lowered look, instead of stock look so i dont think it would work for me. then you got boost controllers to wire in, wastegates to worry about, oil lines to run, oil temp is elevated due to the heat from the turbo. yeah its a little harder to change the pulley, but its not bad loosen the tensioner, and its one 5/8 bolt and its off. there are no oil lines to worry about, theres not 20ft of piping to worry about eitherwith the procharger its all self contained.
Old Mar 30, 2009 | 06:39 PM
  #85
will01's Avatar
Originally Posted by The Fugitive
+1 people just have their preferences is all. S/C is on a belt, turbo has lag for however many secs, you should edit and have people tell what they like and if they had both why they chose one over the other. I would say turbo cause when they are done right they are just swweeeeeeet lol. I am current in the process of getting one, cause i think it has more under the curve power instead of going with the RPMs but I will see what I like. Oh and not to mention, it was said in a post that most of everything is turning to turbos for poweradders and there are car (sorry I should say imports) that run on these all day everyday. So does that say something about reliability?
Good advice right there! I vote S/C and I think my D1SC 8 rib works great for my needs. If I had to do it over again, would make the same choice. What is missing from S/C that turbo can do, dial in boost on the fly - that is pretty cool and can not be done cheaply with a S/C set-up.
Old Mar 31, 2009 | 08:30 AM
  #86
TARZAN's Avatar
I can definitely say I've personally driven an STS car through a MASSIVE thunderstorm, for 50 miles or so through Mobile AL, after gettin it dyno tuned.....car ran fine the whole time and still does today.
-Will
Old Mar 31, 2009 | 11:13 PM
  #87
BigBenz's Avatar
dude STS vs procharger lol. Sts is a cheap power adder. It ok but its like comparing copper to gold.
sorry turbos make more power but are you willing to spend the money? You can make a easy 500rwhp with just a bolt on SC super easy. then move up to 600 or 700 with a built motor. Now can you make 600rwhp on a stock motor? yes anyone can, the problem is you will blow your motor. stock motor is safe around 500rwhp. Now if your going to do a full race set up and have the time and money your going to want a big turbo! not a STS. Save your money for a well built kit. like a APS or even do a custom build with a good turbo.
point is dont get a cheap STS kit get a good turbo kit or a procharger. Theres a reason that this site has a STS help sticky lol
Old Apr 1, 2009 | 01:05 AM
  #88
-Will
well i guess im just extra cautious then. im scared to drive my car (intake in the inner fender/behind front bumper) in the rain.
Old Apr 1, 2009 | 09:10 AM
  #89
OUTLAWZ RACING's Avatar
I voted procharger because I want a f1 unit bad lol!. But my hack up rearmount go down the road pretty good. I think GTO jimmy has shown alot of people/bashers his taillights.
Old Apr 1, 2009 | 12:34 PM
  #90
quicksilverado's Avatar
I made 500 rwhp with a 5.3 and sts at 8 psi. Only other thing on the engine that was not stock was 918 springs and LT headers. Show me a procharger set up that can do that. Sts kits have their pros and cons just like the prochagers.
Old Apr 1, 2009 | 06:42 PM
  #91
quickta98's Avatar
^ ide be there with 8lbs on my P1sc, im at 488rwhp on 6lbs with no meth.
Old Apr 1, 2009 | 10:35 PM
  #92
5.3 or 5.7? I forgot, I did spray methanol since I did not have an I/C at the time.
Old Apr 2, 2009 | 03:07 AM
  #93
this will go on and on lol
everone has their preference, whether you want a turbo or a supercharger there is still one goal in mind...... power
Old Apr 2, 2009 | 11:16 AM
  #94
bravoboost's Avatar
custom kit
aps
procharger
sts
maggie (would have to be the 122)
in that order if your after more than 600whp daily driven
Old Apr 2, 2009 | 12:08 PM
  #95
LS1RedZ's Avatar
Procharger!
Old Apr 5, 2009 | 09:52 AM
  #96
t/a-Donnie's Avatar
Well I rode in ZL1Killa's STS t/a yesterday and it was Bad-A. So I'm finally gonna' cast a vote.(Too bad the poll is closed) Yep, you guessed it, STS. Not that the S/C has a bad sound, but the turbo sound is just freakin' awesome.(And NO, the sound was not what made me cast my vote, but it helped. lol.)
PS I got the T-4 turbo blanket that www.forcedinductions.com sells and it is REAL quality. Don't go cheap. This is the way to go. Super well made. That was my promo plug...now pay me. lol.
