View Poll Results: STS 70mm 8 PSI Turbo(IC) VS Procharger D-1SC 8 PSI(IC)?
23.97%
76.03%
Voters: 121. You may not vote on this poll
STS VS Procharger Poll?!!!!!
Old Mar 28, 2009 | 09:35 PM
  #61
Texas Heat's Avatar
Im not gunna argue over which is better than which, but I will provide my own experience.
I made 630rwhp with my STS on a completely 100% stock LS2 @ 8.5psi with my 70mm STS setup. Ran door to door with 131-132mph trapping cars.
Old Mar 28, 2009 | 09:48 PM
  #62
Turbo 6.0's Avatar
Originally Posted by BOOSTED00SS
Procharger for sure I have a p1 on 7psi, with an epp boost cam, its making 535hp 475tq at the wheels, gets 23mpg on the highway, well mannered pulls harder and harder as the rpms go up all the way to redline, no lag is the best way to go. plus you wont get that sound out of a turbo.
Yeah the sound of a turbo really sucks...
Old Mar 29, 2009 | 06:57 AM
  #63
EPP's Avatar
EPP
Originally Posted by Turbo 6.0
What exactly is the problem with returning oil to the valve cover?
It leads to excessive oil puddling in the top of the right cylinder head, and the STS valvecover connection has a bad habit of coming loose, spewing oil down on to the exhaust manifold/header. Bob
Old Mar 29, 2009 | 02:54 PM
  #64
Turbo 6.0's Avatar
Do you have to remove the oil pan to install the return fitting? We use the valve cover return mostly for ease of installation.
Old Mar 29, 2009 | 04:12 PM
  #65
thobart's Avatar
Default I have one on my trailblazer
Originally Posted by t/a-Donnie
Thanks guys for all the input. Here's the deal. I had decided on STS and ordered one...they dragged their feet and it was taking forever. In the meantime I had a lot of people(like on here) tell me to go Procharger. I called STS to cancel my order..."Oh, well it's already been sent." It figures. But also they charge 20%, yes 20% to return an order. That's like $1100.00. How rediculous is that. So I am stuck with it. I hate to say stuck, but I'm just kind of ticked at their customer service right now as they were supposed to let me know when it shipped. The new updated system with Intercooler looks very sweet, in fact I'm looking at it now. I can't wait to see that IC in the front of my car.
STS has stood behind every issue I have had with it. I make 649 at the crank on 5.8 lbs of boost with the t67 upgrade. If my damn truck was not such a brick I would be crazy fast. the turbo kit works and any system that you buy is only going to be as good as the people who install it. If you need and advice or have questions please feel free to PM me I have lots of experiance with the kit.
Old Mar 29, 2009 | 04:16 PM
  #66
thobart's Avatar
Default Dude not to get into with you
but it is kind of lame for a vendor to bash another vendor!
Old Mar 29, 2009 | 04:17 PM
  #67
thobart's Avatar
Default It is not even close to the same
Originally Posted by elias_799
yes the sts system works, just like a procharger will work if you mount it in the back of the car with a very long belt. but is it a good idea ? whats next ? a maggie where the muffler goes ?
comparison one is designed to work that way and one is not!
Old Mar 29, 2009 | 05:31 PM
  #68
t/a-Donnie's Avatar
I don't see it as "bashing." I just think they have had their own experiences with the kits. What they're discussing is why I started this thread and keep up with it. But this is not my only source for information. Itis always good to have many points of view. You know...towards one common goal. Fast and fun. lol.
Old Mar 29, 2009 | 05:45 PM
  #69
JAX04's Avatar
Yes, procharger over sts yes. But ANY OTHER TURBO OVER ANY SUPERCHARGER!!! YES!!!
Turbo is the way to go. build your own rear mount kit.
Old Mar 29, 2009 | 11:42 PM
  #70
joblo1978's Avatar
I prefer supercharging, and went with roots instead.
I like my headers, I paid alot of money for them, installed them, and love the sound of headers. Wouldn't want to ditch them for turbo manifolds. I also like my catback, would never go with an STS kit. Trans Am's look kinda silly without tail pipes.
Turbo is cool, STS is cool I think too, just needs a little work to be a killer kit. The horsepower is "free" but supercharging is simpler, instant power, and easier.
Technology in kits is so good now that lag is negligable.
Old Mar 30, 2009 | 01:04 AM
  #71
venom ws7's Avatar
The STS Kit is a pain to install the oil return system is crappy , a little laggy
, sounds awesome, will make power
BUT IF I HAD TO CHOOSE I WILL GO WITH D1SC FOR SURE.
Old Mar 30, 2009 | 02:46 AM
  #72
EPP's Avatar
EPP
We do remove the pan to weld a bung on the pan, however a lot of blower kits that use engine oil simply have you poke a hole into the oil pan, then use a tap heavily covered in grease to catch the shavings. If you knew you got all the shavings I suppose this method would work, but it worries me.
Back in '02 we worked on a mid engine Ferrari 308 that had a rear mount turbo. Part of the internals of the catalytic converter had broken loose and shot into the turbo, ruining it. Every now and then we'll have a C5 or C6 on our dyno and we'll see bits of the cats on the ground behind the tailpipes, just make sure that if you go with an STS, take the cats off the car. Bob
Old Mar 30, 2009 | 03:49 AM
  #73
Jimmy P's Avatar
Can't go wrong with either, but I personaly would go with the Procharger. I have been in a STS car before and it was laggy. I know that there are ways to make them more responsive, but its alot of work.
Old Mar 30, 2009 | 05:06 AM
  #74
BOOSTED00SS's Avatar
i never said i didnt like the sound, i just like to hear the sound of a cammed ls1 through true duals plus the whine at idle and blow off valve between shifts you simply cant get a turbo car to sound like that was my point.
Old Mar 30, 2009 | 06:56 AM
  #75
t/a-Donnie's Avatar
The car has NO cats because I had heard of the cats "imploding." lol. What's your experience with the STS kit/oil pump WITH an oil restrictor like mentioned in ZL1Killa's STS post? Specifically an oil restrictor like from "Intingineering."(Here's the link again:
http://www.intengineering.com/063-in...-p3333550.html)
Old Mar 30, 2009 | 09:43 AM
  #76
bravoboost's Avatar
You're right, a proper turbo set-up is hard to beat. To me a proper turbo set-up has the turbo mounted as close to the heat source as possible. APS has the closest thing to an oem proper turbo set-up that I have seen, that is mass produced and can be had quickly when a customer orders one. Bob
Closer to the heat source is the way to do a turbo, not this remote mount noise lol, trying to make up for lag with header wrap, that will eventually just rust the cheap sts piping. STS cars can still be strong though, with "A LOT" of supporting elements. If I didnt have a custom kit, Id go with a APS over a STS or Procharger. I do wish the APS cars were gravity feed though!
Personal preference I know, but I like the turbo sounds, superior MPG, and a powerband dictated by load instead of RPM's....
Old Mar 30, 2009 | 09:46 AM
  #77
bravoboost's Avatar
ur car is an exceptionally strong sts car... most sts GTO's dont run like urs, to say the least lol
Old Mar 30, 2009 | 10:43 AM
  #78
TARZAN's Avatar
I voted STS....We installed an STS kit on my old room mates WS6. The kit was not NEARLY as difficult to install as everybody makes it out to be, and it works great. Also, with a turbo there is no changing pulleys, no worries of belt slip, etc....
-Will
Old Mar 30, 2009 | 10:45 AM
  #79
TARZAN's Avatar
Pun intended? If not, I guess its a preference thing....
-Will
Old Mar 30, 2009 | 11:01 AM
  #80
bravoboost's Avatar
Honestly, that whinning at idle on prochargers sickens me. Sounds like sumthing is broken, or perhaps a vacuum line is leaking etc ... IDK
By Brett Foote | 2026-06-04 05:00:17
