-8cc pistons v's -25cc pistons...
Old 03-31-2009, 06:50 AM
ohplz's Avatar
Originally Posted by Jimmy P
I ended up using -25cc pistons in one of my setups at first, and then when I wanted to raise the compression I had to mill the heads a lot. Dont lower the compression too much as it will make your drivability poor.
so does anyone else have info regarding this setup, -25cc pistons with standard 241 heads over the -8cc pistons with 317 heads????
Old 03-31-2009, 07:40 AM
52172's Avatar
Originally Posted by longrange4u
Hold on fellas... Compression can affect driveability if you lower it too much. Lower compression motor makes less HP but can handle more boost.... Detonation will destroy your motor.... so you dont want that. A street driven boosted motor that you are going to run pumpgas into... (IN MY OPINION) should be below 9:1 Compression ratio... So...
To help you answe these questions you have you have to give us more info... What size motor? How do you drive it? Daily? Semi-Street? Track only? What are your HP goals? What fuel are you going to run?
I'm running 9.8:1 compression on the street with 91 octane no meth and putting down great power with great driveability. Its all in the tune. I also have an oversized a/a intercooler. I would go with the pistons with less dish.
Old 03-31-2009, 08:54 AM
elias_799's Avatar
Originally Posted by Big Bird WS6
so since i have the 225 afr with 72cc, that is good?
oh and i have -11 dish
yes that is pretty good. you will be somewhere around 8.5:1 CR. which i think is perfect for high hp turbo street car
Old 03-31-2009, 09:24 AM
ohplz's Avatar
im still not getting much here? so... -25cc isnt good for high hp?
Old 03-31-2009, 10:55 AM
The Fugitive's Avatar
-25cc is good but you have to understand that you should have a good combination with the heads to lower compression. plus the size of the motor counts. a 418 and up that would be a good piston to use with some 72 chamber heads to get the compression down. but what I am trying to say is don't rely too much on just the piston to lower you compression it will cost a lot of money if it isn't set up right like previously stated. but who knows they have -33cc's out there
Old 03-31-2009, 08:54 PM
elias_799's Avatar
-25cc piston IS NOT GOOD WITH 72CC combustion chamber. you will be in the 7.5:1 compression ratio range. if you are aiming for 1000whp on pump gas maybe but i am sure you are not.
the best way to lower or raise the compression ratio is to do it with the piston. you want a big combustion chamber, it will prevent knock to a point. why do you think diesel engine have pretty much no combustion chamber at all ?
Old 03-31-2009, 09:20 PM
Originally Posted by ohplz
im gonna forge the bottom end to aim for 800+rwhp by adding a MPT78 or a TC78...
whats the better choice? im not going to be running 20 psi or anything ( so i guess? )
but i want to hit 800+rwhp....
can someone explain the pros cons etc... or anything else i should expect etc?
Ummm yea read the whole thread but it is about the combination you don't want to rely on one thing for your setup but we don't know what this setup is for, stop refering to diesel different fuel different setup different power to be made different amount of boost
Old 03-31-2009, 10:05 PM
elias_799's Avatar
diesels use compression to detonate fuel and the lack of a combustion chamber makes it easier to explode under compression, something you do not want happening on you gasoline engine without a spark. i was just trying to show him benefits of using a bigger combustion chamber, no need to be an ******* man.
Old 04-01-2009, 09:19 AM
longrange4u's Avatar
Just for argument sake... My 408 has -32cc Dish Wisco Turboduty Pistons and 72cc chamber heads. She runs fine... likes timming though!
Old 04-01-2009, 09:48 AM
Dumb Ass Vette Moderator
ls1290's Avatar
..., no need to be an ******* man.
And there is no need for name calling.
Old 04-01-2009, 10:01 AM
kp
kp's Avatar
Cant compare a 346 to a 408 when using dish/dome volumes, that same combo you use would be about 1 point of compression less on a 346. Plenty of calculators out there to figure it out, you come out with 8.2:1, that same combo on a 346 = 7.33:1
Lower compression doesnt automatically mean less detonation, if you have a smaller turbo/blower and have to crank it up to move more air to make up for the less compression the extra heat is just as bad as the heat geberated by higher compression. You dont get something for nothing with engines, not to mention chamber design, dome/dish design and even the size of bore itself can affect detonation.
IMO anything between 8.5-9.5:1 is workable on pump fuel. 98 research octane in australia is the same a 92 R+M/2 here.
Old 04-01-2009, 10:13 AM
  #32
SEE!! I told you guys when you started the thread... If you waited long enough someone much more qualified then I would inform you about compression!!!
Old 04-01-2009, 01:02 PM
  #33
what is the size chambers of the heads the starter of this asked about?
Old 04-01-2009, 01:03 PM
  #34
I know right, what I do to him?
Old 04-26-2009, 08:33 AM
  #35
ohplz's Avatar
i was basicly asking, -8cc pistons + 72cc heads or -23cc pistons + 243 heads...
was a interesting one, but think im gonna head towards the -8cc pistons + 72cc heads + mp78 or similar...
will be interesting..
Old 04-26-2009, 01:09 PM
  #36
Jimmy P's Avatar
I know that you arleady have made your choice, but I would also go with -8cc pistons + 72cc heads.
Old 04-26-2009, 03:23 PM
  #37
Johnv's Avatar
Another bonus of using that combo is if you ever decide to go back to N/A, just put the std heads back on and your good to go, no need to swap pistons.
What are the spec's on the MP78, will it make your goals ?
Old 04-27-2009, 01:38 AM
  #38
ohplz's Avatar
yeah man im heading towards the -8cc idea + 72cc heads...
the mp78 i will have to find the specs on, as for turbo selection, ive been told tc78 mpt78 etc...i might even try another garrett if it will work for me.
also whos a good parts suplyer to go through for the rotating assembly anyone? i been dealing with texas speed, is anyone else recomended?
Old 04-27-2009, 05:58 AM
  #39
Denali08's Avatar
317 heads are better because of the thicker deck which is better for higher boost. It all depends on final CR that you want. Assuming all equal, go with -8cc pistons + 72cc heads.
Old 05-17-2009, 02:02 PM
  #40
InsaneDomestics's Avatar
Sorry to bring up an old thread but I was wondering if someone could tell me what dish pistons would give me 9.0-1 CR if Im running a 72cc Head. Can you give me a link to a formula you use to come up with this answer, Thanks!
