Belt slip on 8 rib D1-SC
I'm getting pretty bad slip on my D1-SC. The car hits a wall at 15.5 psi (per kPa value), every time I pull the blower it is covered in rubber dust. This is a 7.65" crank pulley, 3.4" blower pulley, 39.2" 8 rib gatorback and the ATI tensioner almost all of the way down (perhaps an inch of thread to begin, then as it slips it ends up being tightened all the way). Any remedies for this? Anything I can do with the current setup or do any sponsors sell a spring loaded tensioner?
I may try a gates belt and get it pretty tight the first time and see if it holds.
It's the stock filter from the kit. Think freeing up the flow will take some strain off the belt? I noticed you guys were still using the ATI setup on that white T/A that made 700+ too.
The ProCharger air filter is good for about 12 psi of boost, past that it becomes a big restriction. Try a run without the filter, you'll probably be shocked. We've installed larger filters and picked up two psi of boost and eliminated belt slippage. The stock filter becomes such a restriction that it puts a big load on the blower, which causes the belt slippage. Here is the filter we use. http://www.exoticperformanceplus.com...html?item=1086 Bob
