PCV system complete, i think...
Old Apr 5, 2009 | 07:15 PM
dreamls1's Avatar
Default PCV system complete, i think...
just finished up my pcv system, let me know if its right.
I Capped off the back of the PS head. Used the existing line with the pcv valve that goes from the back of the DS head to the inlet of the catch can. Then out the other side of the catch can to the piece on the TB. Then i used the pipe on top of the TB for Boost referance for the wastegate and BOV. Is it ok that i used a T fitting from the BOV to the Wastegate?
Old Apr 5, 2009 | 07:41 PM
98Camarod's Avatar
There's only one port on the TB, did I miss read this?
Old Apr 5, 2009 | 07:55 PM
dreamls1's Avatar
No, the pipe coming out of the tb at the top(you can see in the pic) is feeding the bov and wastegate. Then the is another pipe right under the top one on the tb and I have that hooked up to the out let of the catch can with a check valve inline.
Old Apr 5, 2009 | 07:59 PM
98Camarod's Avatar
Are you talking about the manifold port behind the throttle body?
I wouldn't use that throttle body port for anything, just cap that one. If I were to do it again, I would take the port behind the TB and run it to a vacuum block and have that supply everything. I have mine T'd in various places off of the manifold line.
Old Apr 5, 2009 | 08:06 PM
dreamls1's Avatar
When you say don't use the tv port for anythin, do u mean the one on the very top?
Old Apr 5, 2009 | 08:11 PM
98Camarod's Avatar
I don't know what throttle body you have, but mine and every other one I've seen only has one port as far as vacuum goes on the passenger side. There are the two bottom ones for the coolant to flow through though. On the drivers side there is the TPS and the IAC.
Old Apr 5, 2009 | 08:18 PM
dreamls1's Avatar
I think I was just geting the tb port and manifold port mixed up. So cap the tb port and run my wastegate and bov off the Mani port? Is it ok to run the t fittings like I have them?
Old Apr 5, 2009 | 08:24 PM
98Camarod's Avatar
Look at post #70 and look for forced induction setup:
https://ls1tech.com/forums/generatio...ting-ok-4.html
Old Apr 5, 2009 | 08:28 PM
98Camarod's Avatar
Couple things I see just looking at the pictures:
I'd route the vacuum line some where else instead of between the belt. Also, its hard to tell if there is enough piping there for the clamp to bite on. I'm not sure what kind of line you are using, but I used some shinier hose that was flexed and allowed for zip ties to hold the lines in place. I used brass T's instead of the plastic ones. If there isn't it will blow off. Just a few things to think about.
dreamls1's Avatar
that's what I went off of
Old Apr 5, 2009 | 08:31 PM
dreamls1's Avatar
Oh they are on there I am using hose clamps, just haven't put them on yet.
Old Apr 5, 2009 | 08:35 PM
98Camarod's Avatar
Look at the one that says: "Single Catch Can PCV Routing LS1 Valley Cover, External PCV - Turbo"
You don't want the PCV system hooked up to the manifold. It will pressurize the crankcase under boost. Thats why you run your fresh air line to the inlet of the turbo in between the filter. That way it has vacuum pulling the combustion by products out of the crankcase.
Old Apr 5, 2009 | 08:49 PM
dreamls1's Avatar
Yes, I set it up the same as the diagram. I have a line running from turbo inlet to the valve on the front of the ps head.
Old Apr 5, 2009 | 08:57 PM
98Camarod's Avatar
If you have it setup the same way you explained, its not right. If you have it setup the same as in the diagram then you are ok.
Old Apr 5, 2009 | 09:01 PM
dreamls1's Avatar
Ok, and it's ok to run a T like I have it for the bov and wastegate. That's what I am most worried about.
Old Apr 5, 2009 | 09:04 PM
98Camarod's Avatar
I'm running a T and have had no problems. As long as the connections are good and there isn't any chance of it blowing off then you are good.
Are you running a boost controller or just running off the spring? If you are running a controller, I cant provide much insight. I do know that the wastegate should be supplied by the port on the housing of the turbo.
Old Apr 5, 2009 | 09:27 PM
dreamls1's Avatar
I was told I can run the wg and bov off the manifold port. Is this wrong?
Old Apr 6, 2009 | 05:00 AM
98Camarod's Avatar
If you are just running of the spring, no. But if you have a controller there is a different routing of the lines, I'm not sure how to do that just yet.
Old Apr 6, 2009 | 07:28 AM
dreamls1's Avatar
i am running off the spring right now.
Old Apr 6, 2009 | 02:40 PM
98Camarod's Avatar
Then that's fine.
